This has been driving me bananas for a while, but was hopeful at some point a future release would cure the issue, but the problem persists.
When I connect to my RB4011iGS+5HacQ2HnD 's IP, the default landing page is “Quick Set”.
Since this is not a sensible default for general admin purposes, I’m forced to click “Webfig” to access the features I generally require.
As soon as I click “Webfig” to leave “Quick Set” the connection to the router busts.
However, if I bookmark a path directly to “Webfig” which avoids “Quick Set” such as “1.2.3.4/webfig/#IP:Firewall”, then the problem disappears.
But if I use a bookmark to “1.2.3.4/webfig/” to go directly to webfig, I land in “Quick Set”. Have to link to a specific feature.
Although I’m running RouterOS 7.6, this issue existed in RouterOS v6.
I checked if there was some way to set a preference for the default landing page in the “Webfig” settings, but there isn’t.
Users are forced into the “Quick Set” section.
Although I have a hack setting the bookmark to a path outside of “Quick Set”, can we expect any relief in respect to a fix in a future release?
Even just changing the default FROM “Quick Set” TO “Webfig” would make the fault largely invisible were it not fixed.
Anyhoo, not a show-stopper of a fault, but a persistent PITA for which just changing the landing page could improve usability.
MikroTik?
