I have been using a RB951-2HnD as my SOHO router for the last couple of years, but am now finding that the hardware is not sufficient for my Fibre connection (which is a nice problem to have )
I’m planning to switch to a CCR-1009-8G-1S-1S+PC but am hoping some of the experts here can help me figure out a few things:
I have setup multiple SSID’s on my 951 and am planning to continue using the 951 as a Wireless Access Point after I get my Cloud Router. Due to lack of space in my equipment closet, the Cloud Router and the 951 will not be directly connected but through a unmanaged switch. In this situation, how do I ensure that a client connecting to different SSID’s will be assigned an IP address in the range that is assigned to that SSID?
I’m hoping that I can mostly just export & import the config from my RB951 to the Cloud Router. However, I believe I will have to setup the ethernet master/slave config & bridge config in the Cloud Router by hand but the firewall config can be imported as-is. Am I correct in thinking this?
Depends on if the unmanaged switch will pass vlans. If not, it’s probably best to just buy a managed switch, they are quite cheap by now. Our you could do some tunneling between the routers, like l2tp for each ssid.
I can’t really avoid using a switch as there are only two network points between the equipment closet where the Switch is located and where the CCR will be. In addition there are 6-7 client devices in the equipment closet along with the switch including the RB951. The CCR is a fairly expensive upgrade along with some 5 Ghz equipment I’m buying so I really want to try and use what hardware I have.
Can’t the RB951 tag packets originating from clients associated with the SSID’s? If I can do that now maybe I can use wireshark to check if the switch is currently forwarding vlan headers.
Looking up information that is available on my unmanaged switch, it seems like it does not support VLAN’s. I’ve managed to order a cheap TP-Link managed switch which I will use to replace my D-Link switch.
Given that I will have a managed switch to connect my RB951 to, can someone talk me through broadly what are the steps I need to take to assign different VLAN’s and therefore different IP addresses to clients depending on which SSID they associate with?
