Switching to new ISP-ROS script for bridge+VLAN+static IP please
I know that this topic has probably been done to death, but after reading (and trying) a lot of ideas from posts and wikis, not getting very far.
We are switching to a new ISP that requires VLAN-ID=100 for internet and a /30 static ip address (for EoIP).
This is my first introduction to VLANs with Mikrotik (small businesses so far) and I will be the first to admit that I am just not understanding how RouterOS is handling this.
So if someone can help me with the appropriate scripting, would be appreciated.
  • Hex S v6.41.x
  • WAN Static IP: 127.133.60.14/30
  • WAN Gateway IP: 127.133.60.13
  • eth1 WAN
  • LAN IP: 192.168.1.1/24
  • eth2 LAN
  • eth3-5 other parts of the network
  • currently bridge on all ports (except WAN)
Thanks,
Rob
You can handle the other parts of network as if nothing changed. For the WAN part, these steps should do:
  1. remove ether1 port from bridge if it is part of it now (by default it’s not part of it anyway)
  2. remove any configuration touching ether1 (IP address, DHCP client, interface list membership)
  3. add VLAN configuration to ether1:
/interface vlan
add interface=ether1 name=WAN_vlan100 vlan-id=100
  1. add IP config to the VLAN interface (created in previous step)
add address=127.133.60.14/30 interface=WAN_vlan100
add dst-address=0.0.0.0/0 gateway=127.133.60.13
and adjust interface list membership
add interface=WAN_vlan100 list=WAN
If your router is configured according to current ROS defaults for SOHO devices (enabled firewall, extensive use of interface lists), then you’re almost done.
If your router was heavily customized, then you have to review and adjust firewall filter rules before plugging it to ISP line. Check NAT rules as well.
Will you be using VLANs anywhere else in your setup, and will your interface looking towards the ISP equipment be involved in any way to other VLANs than the required one? Like IPTV broadcasting via some other VLAN on the same interface, connection to your other branch offices provided by the ISP via some other VLAN on the same interface, …?
Thanks both for the replies.
mkx,
I think that you might have nailed it with ‘interface list membership’, will have to try that tomorrow and let you know how it goes.
Sindy,
At the moment just need VLAN ISP facing, but might want to do other VLAN’s later - you have another script suggestion?
Thanks again,
Rob
For “at the moment”, I would have suggested the same what Metod did, but experience has taught me to always think about “later”, that’s why I’ve asked first. hEX S makes some directions of thinking useless due to the poor feature set of the switch chip, but still you have to think about CPU load. In particular: making ether1 a member of the same bridge as the other ether interfaces would be a waste of CPU in the “at the moment” case. But if “later” eventually includes a need to have the same VLAN on ether1 and some other ether, use of a separate bridge to forward that VLAN between ether1 and the other ether if these two ethers weren’t member ports of the same bridge would be even more waste of CPU.
Thanks for the reply sindy,
Let me get it working first, then I can experiment with other options.
Will let you know how it goes.
Hi all,
Thanks for the previous replies - it does connect now - but doesn’t appear to use firewall rules - so disconnected for now.
Applicable config below:
# may/13/2019 14:48:03 by RouterOS 6.44.3
add admin-mac=XXXXXX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1 speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
/interface vlan
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcpClients ranges=192.168.1.101-192.168.1.129
add address-pool=dhcpClients disabled=no interface=bridge lease-time=12h name=serverDhcpClients
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=WAN_vlan100 pvid=100
/interface bridge settings
set allow-fast-path=no use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/ip settings
add address=192.168.1.1/24 comment=ROUTER-GWPRIMARY-1-IP interface=bridge network=192.168.1.0
add address=127.133.60.14/30 interface=WAN_vlan100 network=127.133.60.12
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=yes interface=ether1
add address=192.168.1.0/24 dns-server=192.168.1.1 domain=dummy gateway=192.168.1.1
set allow-remote-requests=no cache-size=5000KiB max-udp-packet-size=512 servers=203.50.2.71,139.130.4.4,8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.1 name=router-gwprimary-1 ttl=18w2d
/ip firewall address-list
add address=192.168.0.0/23 comment="Local network" list=LOCAL_NETWORK
add chain=input comment="Accept established connections" connection-state=established
add action=drop chain=forward comment="Forward allow devnuc 80" dst-port=80 in-interface=ether1 protocol=tcp src-address-list=!DEVWEB_ACCESS_LIST
add action=masquerade chain=srcnat comment="MASQ ether1" out-interface=bridge
add comment=ROUTE-GWPRIMARY distance=1 gateway=127.133.60.13
You have a mix of default and your own rules in the firewall, so some refer to interface-list WAN and some to interface ether1. I’d recommend to replace all occurrences of interface ether1 in the firewall rules by interface-list WAN, and replace ether1 by WAN_vlan100 as a member of interface-list WAN.
43 ;;; Forward allow conf
chain=forward action=drop protocol=tcp src-address-list=!DEVWEB_ACCESS_LIST in-interface-list=WAN dst-port=2663
16 ;;; conf-2663
chain=dstnat action=dst-nat to-addresses=192.168.1.16 to-ports=2663 protocol=tcp in-interface-list=WAN
dst-port=2663
..no forward connection or /ip firewall filter print stats
..sorry, guess I am missing something here..
Post the whole config, the order of lines in the firewall matters so nothing can be concluded from a single line. See my automatic signature for hints on anonymization.
entire config:
# may/13/2019 10:03:08 by RouterOS 6.41.3
# software id = B62N-5JPG
# model = RB760iGS
# serial number = 976E09E5FAF4
add admin-mac=B8:69:F4:01:B8:9F auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=\
    "NBN" mac-address=B8:69:F4:01:B8:9E \
    name=ETHCU1
set [ find default-name=ether2 ] mac-address=B8:69:F4:01:B8:9F
set [ find default-name=ether3 ] mac-address=B8:69:F4:01:B8:A0
set [ find default-name=ether4 ] mac-address=B8:69:F4:01:B8:A1
set [ find default-name=ether5 ] mac-address=B8:69:F4:01:B8:A2
set [ find default-name=sfp1 ] mac-address=B8:69:F4:01:B8:A3
/interface vlan
add interface=ETHCU1 name=WAN_vlan100 vlan-id=100
/ip hotspot profile
add address-pool=dhcpClients disabled=no interface=bridge lease-time=12h name=\
    serverDhcpClients
/snmp community
set [ find default=yes ] addresses=192.168.1.11/32
/ip settings
add address=192.168.1.243/24 comment="Local IP" interface=bridge network=192.168.1.0
add address=192.168.88.1 comment=ROUTER-PROGRAMMING-88.1 interface=bridge network=\
    192.168.88.1
add address=27.33.60.14/30 interface=WAN_vlan100 network=27.33.60.12
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ETHCU1
/ip dhcp-server lease
add address=192.168.1.3 comment=airport-3 mac-address=78:CA:39:FB:95:AC
add address=192.168.1.21 comment=desktop-studio-audio mac-address=40:6C:8F:B7:AC:A8
add address=192.168.1.22 comment=desktop-studio-audio-wifi mac-address=28:37:37:0B:2D:8C
add address=192.168.1.23 comment=desktop-studio-admin mac-address=00:17:F2:02:36:FC
add address=192.168.1.41 comment=desktop-jeff-imac mac-address=0C:4D:E9:C8:FC:75
add address=192.168.1.42 comment=desktop-jeff-imac-wifi mac-address=88:63:DF:AF:2D:FB
add address=192.168.1.45 comment=desktop-piera-imac mac-address=AC:87:A3:12:69:EC
add address=192.168.1.46 comment=desktop-piera-imac-wifi mac-address=88:63:DF:CE:DF:9F
add address=192.168.1.91 comment=centosvm68 mac-address=00:1C:42:0B:43:EC
add address=192.168.1.97 comment=hare2-wifi mac-address=C8:BC:C8:E7:58:81
add address=192.168.1.99 comment=hare-i7 mac-address=F4:5C:89:91:E2:89
add address=192.168.1.0/24 dns-server=192.168.1.1 domain=jtp.local gateway=192.168.1.1
set allow-remote-requests=yes cache-size=5000KiB max-udp-packet-size=512 servers=\
/ip dns static
add address=192.168.1.1 name=router-gwprimary-1.jtp.office ttl=18w2d
add address=192.168.1.1 name=router.jtp.office ttl=18w2d
add address=192.168.1.1 name=jtp.phantomproducer.com ttl=18w2d
add address=192.168.1.3 name=airport-3.jtp.office ttl=18w2d
add address=192.168.1.11 name=devnuc.jtp.office ttl=18w2d
add address=192.168.1.11 name=devnuc.phantomproducer.com ttl=18w2d
add address=192.168.1.16 name=opsnuc.phantomproducer.com ttl=18w2d
add address=192.168.1.16 name=opsnuc.jtp.office ttl=18w2d
add address=192.168.1.16 name=ops.phantomproducer.com ttl=18w2d
add address=192.168.1.21 name=desktop-studio-audio.jtp.office ttl=18w2d
add address=192.168.1.22 name=desktop-studio-audio-wifi.jtp.office ttl=18w2d
add address=192.168.1.23 name=desktop-studio-admin.jtp.office ttl=18w2d
add address=192.168.1.41 name=desktop-jeff-imac.jtp.office ttl=18w2d
add address=192.168.1.42 name=desktop-jeff-imac-wifi.jtp.office ttl=18w2d
add address=192.168.1.43 name=laptop-jeff.jtp.office ttl=18w2d
add address=192.168.1.44 name=laptop-jeff-wifi.jtp.office ttl=18w2d
add address=192.168.1.45 name=desktop-piera-imac.jtp.office ttl=18w2d
add address=192.168.1.46 name=desktop-piera-imac-wifi.jtp.office ttl=18w2d
add address=192.168.1.91 name=centosvm68.jtp.office ttl=18w2d
add address=192.168.1.97 name=hare2-wifi.jtp.office ttl=18w2d
add address=192.168.1.99 name=hare-i7.jtp.office ttl=18w2d
add address=192.168.1.99 name=dev.and.phantomproducer.jtp.office ttl=18w2d
add address=192.168.1.99 name=dev-hare-old.phantomproducer.com ttl=18w2d
add address=192.168.1.99 name=dev-hare-cruncher1.phantomproducer.com ttl=18w2d
add address=192.168.1.99 name=dev-hare-api.phantomproducer.com ttl=18w2d
add address=192.168.1.99 name=dev-hare-my.phantomproducer.com ttl=18w2d
add address=192.168.1.99 name=dev-hare-www.phantomproducer.com ttl=18w2d
add address=192.168.1.99 name=dev-hare-ppweb.phantomproducer.com ttl=18w2d
add address=192.168.1.11 name=dev-old.phantomproducer.com ttl=30m
add address=192.168.1.11 name=dev-api.phantomproducer.com ttl=30m
add address=192.168.1.11 name=dev-cruncher.phantomproducer.com ttl=30m
add address=192.168.1.99 name=dev-and.phantomproducer.com ttl=18w2d
add address=192.168.1.11 name=dev2-www.phantomproducer.com ttl=30m
add address=192.168.1.11 name=dev-my.phantomproducer.com ttl=30m
add address=192.168.1.11 name=dev-www.phantomproducer.com ttl=30m
add address=192.168.1.11 name=dev-ppweb.phantomproducer.com ttl=30m
add address=192.168.1.11 name=dev-www.killerhertz.com ttl=30m
add address=192.168.1.99 name=dev-hare-www.killerhertz.com ttl=18w2d
add address=192.168.1.11 name=jenk.phantomproducer.com ttl=30m
add address=192.168.1.11 name=graf.phantomproducer.com ttl=30m
add address=192.168.1.16 name=ops-www.phantomproducer.com ttl=30m
add address=192.168.1.16 name=jira.phantomproducer.com ttl=30m
add address=192.168.1.16 name=conf.phantomproducer.com ttl=30m
add address=192.168.1.16 name=nfsn.phantomproducer.com ttl=30m
add address=192.168.1.16 name=onms.phantomproducer.com ttl=30m
add address=192.168.0.0/23 comment="Local network-TRUSTED" list=TRUSTED_ACCESS_LIST
add address=14.202.176.48 comment=TRUSTED_ACCESS_LIST-RRG list=TRUSTED_ACCESS_LIST
add address=14.202.176.48 comment=SYSADMIN_ACCESS_LIST-RRG list=SYSADMIN_ACCESS_LIST
add address=50.18.201.134 comment="SYSADMIN_ACCESS_LIST-Phantom temp" list=\
add address=52.9.119.145 comment="SYSADMIN_ACCESS_LIST-khz temp" list=SYSADMIN_ACCESS_LIST
add address=52.9.94.67 comment=OpenNMS-phantomproducer.com-cruncher0001 list=\
add address=192.168.1.11 comment=SYSADMIN_ACCESS_LIST list=SYSADMIN_ACCESS_LIST
add address=50.18.201.134 comment="Rate limited-phantomproducer.com-primary" list=\
    RL_PHAN_WEBSITES
add address=52.9.119.145 comment="Rate limited-killerhertz.com-primary" list=RL_PHAN_WEBSITES
add address=107.21.126.167 list=DROPBOX
add address=54.221.249.127 list=DROPBOX
add address=50.19.125.179 list=DROPBOX
add address=174.129.26.151 list=DROPBOX
add address=14.202.176.48 comment=DEVWEB_ACCESS_LIST-RRG list=DEVWEB_ACCESS_LIST
add address=101.190.55.165 comment="DEVWEB_ACCESS_LIST-JT Home" list=DEVWEB_ACCESS_LIST
add address=58.173.131.206 comment="DEVWEB_ACCESS_LIST-Adz home" list=DEVWEB_ACCESS_LIST
add address=101.190.0.0/16 comment="DEVWEB_ACCESS_LIST-Jeff home temp" list=\
    DEVWEB_ACCESS_LIST
add address=110.145.250.54 comment="DEVWEB_ACCESS_LIST-Jeff travel temp" list=\
    DEVWEB_ACCESS_LIST
add address=14.202.176.48 comment=WHITELIST_SSH-RRG list=WHITELIST_SSH
add address=192.168.0.0/23 comment="WHITELIST_SSH-Local network" list=WHITELIST_SSH
add address=58.108.167.24 comment="WHITELIST_SSH-Adz home" list=WHITELIST_SSH
add address=14.202.176.48 comment=WHITELIST_FTP-RRG list=WHITELIST_FTP
add address=50.18.201.134 comment=WHITELIST_FTP-phantom list=WHITELIST_FTP
add chain=input comment="Accept related connections" connection-state=related
add action=drop chain=input comment="Drop invalid connections" connection-state=invalid
add chain=input comment="Allow access to router from known networks and remote servers" \
    src-address-list=TRUSTED_ACCESS_LIST
add action=drop chain=input comment="Drop excess pings" protocol=icmp
add action=drop chain=input comment="Drop everything else"
add action=drop chain=forward comment="TCP flags and Port 0 attacks" protocol=tcp tcp-flags=\
    !fin,!syn,!rst,!ack
add action=drop chain=forward protocol=tcp tcp-flags=fin,syn
add action=drop chain=forward protocol=tcp tcp-flags=fin,rst
add action=drop chain=forward protocol=tcp tcp-flags=fin,!ack
add action=drop chain=forward protocol=tcp tcp-flags=fin,urg
add action=drop chain=forward protocol=tcp tcp-flags=syn,rst
add action=drop chain=forward protocol=tcp tcp-flags=rst,urg
add action=drop chain=forward protocol=tcp src-port=0
add action=drop chain=forward dst-port=0 protocol=tcp
add action=drop chain=forward protocol=udp src-port=0
add action=drop chain=forward dst-port=0 protocol=udp
add chain=forward connection-state=established
add chain=output connection-state=established
add chain=output connection-state=related
add action=drop chain=output connection-state=invalid
add action=drop chain=input src-address-list=BLACKLIST_BOGONS
add action=drop chain=input src-address-list=BLACKLIST_MANUAL
add action=drop chain=input src-address-list=BLACKLIST_FAIL2BAN
add action=drop chain=forward src-address-list=BLACKLIST_BOGONS
add action=drop chain=forward src-address-list=BLACKLIST_MANUAL
add action=drop chain=forward src-address-list=BLACKLIST_FAIL2BAN
add action=drop chain=forward comment="Forward allow devnuc 80" dst-port=80 in-interface=\
    ETHCU1 protocol=tcp src-address-list=!DEVWEB_ACCESS_LIST
add action=drop chain=forward comment="Forward allow devnuc 443" dst-port=443 in-interface=\
add action=drop chain=forward comment="Forward allow SYSADMIN to - onms.phantomproducer.com" \
    dst-port=8980 in-interface=ETHCU1 protocol=tcp src-address-list=!SYSADMIN_ACCESS_LIST
    "Forward allow minions to - onms.phantomproducer.com:8981" dst-port=8981 in-interface=\
    "Forward allow minions/ActiveMQ to - onms.phantomproducer.com:61616" dst-port=61616 \
    "Forward allow minions/ActiveMQ to - onms.phantomproducer.com:8443" dst-port=8443 \
add action=drop chain=forward comment="forward-drop dst-port=22,222,223 !WHITELIST_SSH" \
    dst-port=22,222,223 in-bridge-port=WAN_vlan100 protocol=tcp src-address-list=\
    !WHITELIST_SSH
add action=drop chain=forward comment="forward-drop dst-port=20,21 !WHITELIST_FTP" dst-port=\
    20,21 in-interface=ETHCU1 protocol=tcp src-address-list=!WHITELIST_FTP
add action=drop chain=forward comment="Forward allow jenk.phantom" dst-port=5365 \
    in-interface=ETHCU1 protocol=tcp src-address-list=!DEVWEB_ACCESS_LIST
add action=drop chain=forward comment="Forward allow graf.phantom" dst-port=3000 \
add action=drop chain=forward comment="Forward allow postgres" dst-port=5432 in-interface=\
add action=drop chain=forward comment="Forward allow elasticsearch-ui" dst-port=5601 \
add action=drop chain=forward comment="Forward allow elasticsearch" dst-port=9200 \
add action=drop chain=forward comment="Forward allow nfsen.phantom" dst-port=6376 \
add action=drop chain=forward comment="Forward allow jira.phantom" dst-port=5472 \
    in-interface=bridge protocol=tcp src-address-list=!DEVWEB_ACCESS_LIST
add action=drop chain=forward comment="Forward allow conf.phantom" dst-port=2663 \
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=\
    out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment="MASQ ETHCU1" out-interface=bridge
add action=dst-nat chain=dstnat comment="SSH to .11-22" dst-port=22 in-interface=ETHCU1 log=\
    yes protocol=tcp to-addresses=192.168.1.11 to-ports=22
add action=dst-nat chain=dstnat comment="SSH to .11-222" dst-port=222 in-interface=bridge \
    log=yes protocol=tcp to-addresses=192.168.1.11 to-ports=222
add action=dst-nat chain=dstnat comment=devnuc-80 dst-port=80 in-interface=ETHCU1 protocol=\
    tcp to-addresses=192.168.1.11 to-ports=80
add action=dst-nat chain=dstnat comment=devnuc-443 dst-port=443 in-interface=ETHCU1 protocol=\
    tcp to-addresses=192.168.1.11 to-ports=443
add action=dst-nat chain=dstnat comment="devnuc-ftp temp-20" dst-port=20 in-interface=ETHCU1 \
    protocol=tcp to-addresses=192.168.1.11 to-ports=20
add action=dst-nat chain=dstnat comment="devnuc-ftp temp-21" dst-port=21 in-interface=ETHCU1 \
    protocol=tcp to-addresses=192.168.1.11 to-ports=21
add action=dst-nat chain=dstnat comment=jenkins-5365 dst-port=5365 in-interface=ETHCU1 \
    protocol=tcp to-addresses=192.168.1.11 to-ports=5365
add action=dst-nat chain=dstnat comment=service-grafana-3000 dst-port=3000 in-interface=\
    ETHCU1 protocol=tcp to-addresses=192.168.1.11 to-ports=3000
add action=dst-nat chain=dstnat comment=PostGres-5432 dst-port=5432 in-interface=ETHCU1 \
    protocol=tcp to-addresses=192.168.1.11 to-ports=5432
add action=dst-nat chain=dstnat comment=opsnuc-jira-5472 dst-port=5472 in-interface=ETHCU1 \
    protocol=tcp to-addresses=192.168.1.16 to-ports=5472
add action=dst-nat chain=dstnat comment=opsnuc-confluence-2663 dst-port=2663 in-interface=\
    ETHCU1 protocol=tcp to-addresses=192.168.1.16 to-ports=2663
add action=dst-nat chain=dstnat comment=opsnuc-nfsen-6376 dst-port=6376 in-interface=ETHCU1 \
    protocol=tcp to-addresses=192.168.1.16 to-ports=6376
add action=dst-nat chain=dstnat comment="opsnuc-OpenNMS UI:443/8980" dst-port=8980 \
    in-interface=ETHCU1 protocol=tcp to-addresses=192.168.1.16 to-ports=8980
add action=dst-nat chain=dstnat comment="devnuc-OpenNMS 8443" dst-port=8443 in-interface=\
    ETHCU1 protocol=tcp to-addresses=192.168.1.16 to-ports=8443
add action=dst-nat chain=dstnat comment=devnuc-OpenNMS-Minions-ActiveMQ dst-port=61616 \
    in-interface=ETHCU1 protocol=tcp to-addresses=192.168.1.16 to-ports=61616
add comment=ROUTE-GWPRIMARY distance=1 gateway=27.33.60.13
..would have thought that this would have been a really easy thing to do..
It is an easy thing to do. The problem is that you have renamed ether1 to ETHCU1 but took my advice to update the firewall literally, i.e. you’ve changed only rules referring to ether1 (which were clearly not working already in that state as they referred to a non-existent interface name) but haven’t changed rules referring to ETHCU1 (which is the physical ether1 but known under your customized name).
The IP firewall cannot see the packets as coming in via ETHCU1 because the IP configuration is attached to WAN_vlan100. So replace all references to (in|out)-interface=ETHCU1 by references to (in|out)-interface-list=WAN and you should be good.
Thanks sindy, will try that tomorrow
