GREETINGS,
I switched to SWOS trying to do some vlan testing but when the switch reboots I can’t access to it from the winbox nor from the default address any help please?
GREETINGS,
SWOS is not managed by WinBox, only HTTP/HTTPS
In the Neighbors tab half way down the screen in WinBox where you select what system to connect to, you MIGHT see your switch (depends on a setting in the switch). Selecting it there will bring up a browser session.
thanks I ffigured that out after few tries
thanks for your reply
thank you sir i just figured that out
thanks a lot
i did not know SWOS supports HTTPS management
Do not have any support for httpS
No HTTPS, (no support for certificates etc.)
