High friends. Is any way to simulating the switchos on x86 ?
Sent from my SM-A705FN using Tapatalk
You can simulate RouterOS using GNS3…
Thanks. But I need switchos
I doubt it can be done easily. My impression is that SwOS is only an UI to configure switch chip (more or less the /interface ethernet under ROS) … if the same was wanted on x86, whole switch chip logic would have to be implemented … which is already done as /interface bridge under ROS …
