Swith ACL redirect-to-cpu question
I am curios about the redirect-to-cpu ACL rule action.
Hardware offload is enabled on the bridge. All ports show Hardware Offload as being active.
I have the following test configuration:
add admin-mac=00:11:22:33:44:55 auto-mac=no comment=defconf name=bridgeLocal
add bridge=bridgeLocal comment=defconf interface=ether1 hw=yes
add bridge=bridgeLocal comment=defconf interface=ether2 hw=yes
add bridge=bridgeLocal comment=defconf interface=ether3 hw=yes
add bridge=bridgeLocal comment=defconf interface=ether4 hw=yes
add bridge=bridgeLocal comment=defconf interface=ether5 hw=yes
/interface bridge settings
/interface bridge settings set allow-fast-path=yes use-ip-firewall=yes
/interface ethernet switch rule
add dst-address=192.168.88.88/32 dst-port=22 ports=ether4 protocol=tcp
redirect-to-cpu=yes switch=switch1
I have no IP firewall rules, so the packet should go back to the switch after reaching the IP firewall.
The switch ACL rule checks whether the packet is destined to 192.168.88.88 on tcp port 22 and it will redirect this packet to the switch-CPU. All well and good, I can se the packet on the prerouting chain but I don’t know how to forward the packet back to the switch, whenever the rule is active, the redirected traffic acts as if it’s being dropped.
I’ve read the packet flow and whether the packet receives additional processing or not, it should go back to the switch-cpu as it’s destination is outside the router.
Am I missing something?
Thank you.
No one knows anything about this?
You possibly also need a bridge nat rule to kick the packet into the routing section of the device.
Something like:
/interface bridge nat
add action=redirect chain=dstnat disabled=no dst-address=192.168.88.88 ip-protocol=tcp dst-port=22 log=yes mac-protocol=ip
It worked!
Now it makes sense, I was not redirecting the packet back to the bridge. The packet was reaching the CPU for additional processing but was not being redirected back to the bridge.
Thank you!
