CollectD - a monitoring tool - uses SnmpGetNext request to fetch various interface counters. This does not work with RB250G running SwOS 1.6, as it replies back with a malformed packget when CollectD tries to request data for the non-existent Port6:
2012-06-21T17:13:52+00:00 localhost daemon info collectd[5022]: snmp plugin: host 44.128.156.98: snmp_sess_synch_response successful.
2012-06-21T17:13:53+00:00 localhost daemon err collectd[5022]: snmp plugin: host 44.128.156.98: snmp_sess_synch_response failed: Timeout (parse header: message overflow: 75 len + 2 delta > 61 len)
tcpdump output shows that:
17:11:32.483825 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 105)
44.128.156.1.47970 > 44.128.156.98.161: [bad udp cksum 0x91ca -> 0xe003!] { SNMPv1 { GetNextRequest(62) R=2055248100 .1.3.6.1.2.1.2.2.1.14.5 .1.3.6.1.2.1.2.2.1.20.5 .1.3.6.1.2.1.2.2.1.2.5 } }
17:11:32.485484 IP (tos 0x0, ttl 254, id 39635, offset 0, flags [none], proto UDP (17), length 89)
44.128.156.98.161 > 44.128.156.1.47970: [udp sum ok] [len59<asnlen75]
And yes, I can reproduce it manually:
With physical port 5:
# PORT=4
# snmpgetnext -v 1 -c public 44.128.156.98 .1.3.6.1.2.1.2.2.1.14.${PORT} .1.3.6.1.2.1.2.2.1.20.${PORT} .1.3.6.1.2.1.2.2.1.2.${PORT}
17:06:35.976060 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 105)
44.128.156.1.47831 > 44.128.156.98.161: [bad udp cksum 0x91ca -> 0x47ad!] { SNMPv1 { GetNextRequest(62) R=1071494435 .1.3.6.1.2.1.2.2.1.14.4 .1.3.6.1.2.1.2.2.1.20.4 .1.3.6.1.2.1.2.2.1.2.4 } }
17:06:35.977886 IP (tos 0x0, ttl 254, id 15059, offset 0, flags [none], proto UDP (17), length 112)
44.128.156.98.161 > 44.128.156.1.47831: [udp sum ok] { SNMPv1 { GetResponse(69) R=1071494435 .1.3.6.1.2.1.2.2.1.14.5=0 .1.3.6.1.2.1.2.2.1.20.5=0 .1.3.6.1.2.1.2.2.1.2.5="Port5" } }
IF-MIB::ifInErrors.5 = Counter32: 0
IF-MIB::ifOutErrors.5 = Counter32: 0
IF-MIB::ifDescr.5 = STRING: Port5
Trying to get the next OID in tree, refering non-existing to physical port 6:
# PORT=5
17:06:39.548947 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 105)
44.128.156.1.43823 > 44.128.156.98.161: [bad udp cksum 0x91ca -> 0x9249!] { SNMPv1 { GetNextRequest(62) R=26214195 .1.3.6.1.2.1.2.2.1.14.5 .1.3.6.1.2.1.2.2.1.20.5 .1.3.6.1.2.1.2.2.1.2.5 } }
17:06:39.550805 IP (tos 0x0, ttl 254, id 15315, offset 0, flags [none], proto UDP (17), length 89)
44.128.156.98.161 > 44.128.156.1.43823: [udp sum ok] [len59<asnlen75]
Timeout: No Response from 44.128.156.98.
It sould response with the next OID in the tree or with a message when the request has ended the tree, like:
44.128.156.98.161 > 44.128.156.1.52598: [udp sum ok] { SNMPv1 { GetResponse(30) R=1971931419 noSuchName@1 .1.3.6.1.2.1.2.2.1.20.5= } }
Please FIX it.
