SwOs 2.13 PoE problems
Hello all, running into an issue. I have a CRS354-48P-4S+2Q+. On all even ports I can’t off PoE. I had set PoE off on web interface but switch still try to detect PoE devices on even ports.
Hi, similar problem on CRS354-48P-4S+2Q+ (SWOS 2.16). The AP’s with PoE: ports 1 to 8 is working, ports 9 to 16 are not working, ports 17 to 26 are working…
But I think this is due to the fact that I updated via the web interface and it downloaded the update for CRS326.
I downloaded the update specifically for CRS354 from the site and will try to update it manually.
These thoughts came to me as a result of the fact that I know that switches are assembled in boards/blocks of 8 or 12 or 16 ports and searching for a solution to the problem on the Internet… although this is not directly stated anywhere, I read that support was only recently added to SWOS CRS354 and saw problems with other users that it incorrectly defines SWOS and SWOS-light
Not work, the first time worked but after night down equipment - but in web-interface status up and indicators flashed
