SwOS 2.15?
I saw this as an available upgrade on my RG260GS
What’s new in v2.15:
*) factory only release
What’s new in v2.14:
Is this by mistake?
RB260GS (CSS106-5G-1S)
RB260GSP (CSS106-1G-4P-1S)
2.14
https://download.mikrotik.com/swos2/css106/swos-css106-2.14.bin
Latest for CSS106-x-x (RB260GSx) is 2.15.1660901112 but actually is unavailable for download.
The full changelog:
What's new in v2.15:
What's new in v2.14:
What's new in v2.13:
*) added support for CRS354;
*) CRS328: fixed SFP status monitoring;
*) CRS328: fixed auto-negotiation on combo ports;
*) CRS326Q: fixed matching by ports in ACL;
*) CRS326Q: properly detect QSFP+ optical modules;
*) CRS326Q: properly detect QSFP+ DAC cable;
*) CRS326Q: fixed case where some deleted ACL rules were still active;
*) CRS305: make auto upgrade work;
*) CRS312: fixed 2.5G & 5G modes;
*) CRS312 & CRS326Q: fixed SNMP ifAdminStatus & ifOperStatus;
*) CRS312 & CRS326Q: do not freeze when showing Host tab with no entries;
*) CRS312 & CRS326Q & CRS309: fixed ingress rate limiter;
*) CSS106: added reset-counters to Statistics tab;
*) CSS106: make RSTP work with vlanMode=enabled or vlanMode=strict;
*) CSS106: fixed IGMP, PPPoE & DHCP snooping of VLAN tagged packets;
*) CSS106: make port isolation work when vlanMode=enabled or vlanMode=strict;
*) CRS318fi: make 1G ports link with other routerboards;
*) CRS309: fixed tx flow control;
*) CRS305: fixed traffic forwarding between SFP+ ports;
*) fixed ingress traffic port mirroring on first port;
*) fixed dst. & src. port matcher in ACL;
*) fixed redirect-to in ACL;
*) fixed storm rate limiter on SFP+ ports working in 1G mode;
*) fixed storm rate limiter on 40G links;
*) correctly recognize some copper SFP modules;
*) added name to VLAN entries;
*) fixed VLAN entry management when they were added unordered;
*) fixed IGMP snooping - stop forwarding multicast packets
   if there are no more listeners;
*) added support for IGMP fast leave;
*) always forward link local IPv4 & IPV6 packets;
*) fixed password changing on Chrome and IE;
*) do not renew DHCP address and restart RSTP on any System tab change;
*) reset error & histogram counters separately from main ones;
*) report correct ifSpeed & ifHIghSpeed for ports with no active links;
*) fixed crash when receiving jumbo frames on management CPU;
What's new in v2.12:
*) added Combo-Mode setting for combo ports;
*) allow to configure tx & rx flow control separately (only tx flow control
   is enabled by default) and make them work;
*) report current status of rx/tx flow control;
*) report correctly rx/tx pause frames under Errors tab;
*) report that link is paused under Links tab;
*) report tx queue size under Stats tab;
*) make sure that SwOS is still responsive when most of SFP modules are plugged in;
*) fixed problem where switch locked up after a while and only small packets could be sent;
*) fixed problem where sometimes by loading bigger backup files switch
   went into reboot loop;
*) make LACP keep working even if only one port is active in trunk
   (helps with fail-over);
*) fixed problem where changing LAG mode from static to active did not work;
*) CRS328C & CRS326S: make switch accessible by web
   if all SFP modules are plugged in;
*) CRS312: fixed combo ports LEDs;
*) CRS312: fixed problem where traffic on combo ports stopped working after reboot;
*) CRS328C: added support for 100Base-FX modules;
*) CRS328C: make DAC link work with CCR boards regular SFP ports;
*) CRS326Q: allow to force 10Gx4 or 40G mode on QSFP ports;
*) CRS326Q: report QSFP module status;
*) CRS328P: report correctly PoE values via SNMP;
*) CRS309: added support for ETH/BOOT port configuration;
*) CSS106: report correctly PoE & SFP values via SNMP;
*) CSS106: fixed IGMP packet forwarding when snooping is enabled;
*) CSS106: fixed SFP LED;
*) CSS106: fixed ACL, sometimes it did not work if MAC & IP address matchers
   were used at same time (or when Allow-From address was specified);
*) CSS106: handle properly unknown unicast packets (do not try to send them to CPU),
   otherwise under load it impacts forwarding speed of the switch;
*) CSS106: do not allow to access switch by VLAN from port that is not member
   of that VLAN if port is in strict or enabled VLAN mode;
*) CSS106: make static hosts work in IVL mode;
What's new in v2.11:
*) try to acquire DHCP address even after initial 10s if
   static address is provided use it while DHCP has not succeeded;
*) fixed QnQ (VLAN in VLAN) packet forwarding;
*) make flow-control disable work as expected;
*) make static LAG work;
*) CRS328: fixed errors on SFP ports;
*) CRS312 & CRS326Q: fixed ACL matching by IP source port;
*) CRS317: make speed forcing work on management port;
*) CRS312: make 1G speed forcing work on combo ports;
*) CRS312 & CRS326Q: fixed management port leds;
*) CRS312: do not reset all links on new SFP module plug in;
What's new in v2.10:
*) do not ignore RSTP port state when forwarding DHCP, PPPoE or IGMP snooped packets;
*) IGMP snooping: send out IGMPv3 queries by default;
*) IGMP	snooping: handle IGMPv3 leaves much better;
*) IGMP snooping: handle dropped IGMP reports much better;
*) CRS309, CRS312, CRS317, CRS326Q: fixed ACL matching by ip destination port;
*) CRS309, CRS312, CRS317, CRS326Q: fixed ICMP TTL packet switching;
*) CRS305, CSS106: make ACL work again;
*) CSS106: improve packet forwarding between different speed interfaces;
*) restart RSTP on LACP ports that got disbundled;
*) made disabling of flow-control work as expected;
*) do not account rx-overflows twice in SNMP ifInErrors;
*) CRS328-24P-4S+: make auto upgrade work;
*) CRS326Q: fixed vlan configuration on ports sfp22-sfp24 & qsfp+1.1-qsfp+2.4;
*) added support for unicode symbols in labels;
*) make DHCP & PPPoE snooping work correctly on port trunks;
*) made port lock filter out packets with unknown source addresses;
*) CRS309: make VLAN configuration work;
*) fixed problem where disabled autonegotiation on some SFP modules
   became effective only after reboot;
*) CRS305, CRS326, CRS328: improved switch-chip resource allocation;
What's new in v2.9:
*) CRS326 & CRS328 & CRS317: make sure that RSTP BPDU packets are always untagged;
*) CRS328-4C-20S-4S+: make 1G fiber SFP modules work;
*) CRS328-4C-20S-4S+: fixed PSU numbering;
*) CRS328-4C-20S-4S+: light up fault LED on fan failure;
*) CRS328-4C-20S-4S+: make fiber optic SFP modules work;
*) CRS328-24P-4S+: light up fault LED on fan failure;
*) CRS317: make fault led light up on fan failure;
*) CSS106: fixed rx/tx unicast packet counter;
*) CSS106: make low speed ports not block high speed port traffic;
*) make forced ethernet speeds work;
*) added ability to block unknown multicast packets on port;
*) fixed reporting of secondary FAN speeds;
*) fixed problem where sometimes all VLANs or ACLs were not saved;
*) fixed DHCP snooping to forward packets when they are bigger than 300 bytes;
*) made DHCP snooping remove DHCP agent information option from DHCP replies;
*) made DHCP snooping respect port isolation;
*) fixed SFP module wrong info problem;
*) made LACP work together with RSTP;
*) made upgrading over serial work;
What's new in v2.8:
*) CRS317: fixed links not coming up after power failure;
*) CRS317: added extra information about FAN & PSU health;
*) CRS317: fixed load balancing over aggregated links;
*) CRS317: increased per port queue size;
*) CRS328-24P-4S+: make FAN work;
*) CRS328-24P-4S+: added extra information about health;
*) CRS328-24P-4S+: do not power cycle PoE outputs on reboot;
*) CRS328-24P-4S+: added voltage-level setting;
*) CRS328-24P-4S+: make SFP3 port work;
*) CRS328-24P-4S+: expose PoE port status via SNMP;
*) CRS328-4C-20S-4S+: make FAN work;
*) CRS328-4C-20S-4S+: added extra information about health;
*) CSS106: expose PoE port status via SNMP;
*) CSS106: always strip VLAN header on ports with disabled VLAN mode;
*) CSS106: make access to SwOS work over VLAN 1, put vlan header in replies;
*) CSS106: do not vlan tag RSTP BPDU packets, makes RSTP work with RouterOS;
*) CSS106: forward IGMP query messages even when IGMP snooping is disabled;
*) make PPPoE & DHCP snooping work on CRS326 & CRS328;
*) CRS326 & CRS328: make removed ACL rule stop working;
*) CRS326 & CRS328: learn MAC addresses even redirecting packets from ACL;
*) CRS326 & CRS328 & CRS317: added strict VLAN mode;
*) if "Allow From VLAN" is specified, make discovery packets use it;
*) make DHCP client work with RFC non compliant DHCP servers;
*) do not allow to create multiple VLANs with the same id;
*) provide health information (temperature, fan speed, psu state) via SNMP;
*) provide SFP port health information via SNMP;
*) use 64bit counters under Stats tab for byte accounting;
What's new in v2.7:
*) Make some of Mikrotik DAC work in 10G mode;
*) Make SwOS work with MS Internet Explorer 11;
*) Fixed switch lockup if it was restored with specifically corrupted backup file;
What's new in v2.6:
*) Make 'Change Password' work again;
*) CRS317 & CRS326: fixed DHCP request forwarding between trusted ports;
*) CRS317 & CRS326: fixed ACL vlanid match (values bigger than 1024 did not work);
*) CSS106-5G-1S: do not show health menu;
*) make upgrading work from Safari;
*) fixed saving of large lists of VLANs or ACLs;
*) fixed SNMP host table interface indexes;
*) fixed VLAN table sorting;
*) CSS106: fixed upgrading (to upgrade from v2.5 hit upgrade & then after a while reboot);
What's new in v2.5:
*) SFP & SFP Status tabs are combined into one;
*) Global RSTP settings are moved unto RSTP tab;
*) Static Hosts & Hosts tabs are combined into one;
*) CSS106, CRS326, CRS317: added support for IGMP snooping;
*) CRS326 & CRS317: fixed occasional lockup on SFP module insertion;
*) CSS106: added global	independent VLAN lookup option for all VLANs;
*) CSS106: do not enable IVL on reboot if it's disabled;
*) implemented DHCP client;
*) CRS326 & CRS317: added support for DHCP & PPPoE snooping and
   injecting option 82 (Intermediate Agent info);
*) CRS317: support fans;
CAVEAT: switch address acquisition mode by default is DHCP with fallback to static address;
What's new in v2.4:
*) CSS106: fixed upgrade over PoE ports when PoE stopped working;
*) CRS326: fixed port in disabled VLAN mode to forward untagged packets;
What's new in v2.3:
*) fixed CRS317: make 10G links more stable;
*) fixed "Allow From VLAN" on untagged packets with correct default vlan id;
*) LACP: fixed unstable aggregate link problem when partner had short retransmit timer;
*) CSS326 & CRS317: made 1Gb fiber SFP module work with auto negotiation;
*) CSS106: do not VLAN tag RSTP packets;
What's new in v2.2:
*) fixed CSS326 & CRS317 switch MAC address;
*) fixed CRS317 lockup;
*) make CSS326 & CRS317 10G links more stable;
*) fixed CRS317 temperature reading;
*) fixed problem where big ACL, VLAN or static hosts lists kept only couple of first entries;
*) made "Save Backup" work on CSS106;
*) SNMP: report always 0 in IF-MIB:ifOutQLen;
*) CSS106: report correct speed for SFP port via SNMP;
What's new in v2.1:
*) added support for per port and ACL ingress rate limitation to CSS326 & CRS317;
*) added support for LACP in CSS326 & CRS317;
*) fixed CSS106 accessing over VLAN;
*) fixed CSS106 ACL rules that change VLANs;
*) added tx/rx rates per port to CSS106;
*) SNMP: added support for BRIDGE MIB;
*) SNMP: added support for GetBulkRequest;
My guess: Factory only releases are for changed components (different memory chips, different power management controller etc..)
Exactly, but if is not available for download can cause only problems.
Older devices will not have those changed components and do not need a software update.
In ROS (same vendor) we have firmware file (called routerboot) with version number always matching ROS version number. For older devices most of times the difference against previous is only in version number. And yet ROS persistently offers to upgrade firmware.
My point being: for simplicity of maintenance of a fleet of devices it’s good to have the releases for all devices so admins don’t have to keep track of latest versions for different device models. (This, BTW, was more or less the reasoning behind the change of firmware versioning … I just re-phrased it)
Wow… that is really not what I was expecting from a new SwOS release.
Is it so hard to finally push out a bugfix release for existing devices?
This is also very confusing. Both my CRS312-4C+8XG and my CRS305-1G-4S+ are showing
However when you click “Download & Upgrade” you get the following error - ERROR: Could not retrieve firmware. A factual explanation would be nice.
I see the same issue on CRS326-24G-2S+ devices. It reports “ERROR: Could not retrieve firmware”. So what is the solution here? Do we have to wait until the update files appear, or can this just be ignored?
Why release a new version when there are no bugfixes in it?
There was an error in the SwOS upgrade server which provided false information about SwOS 2.14 and 2.15 releases.
It has been fixed now and the SwOS 2.13 is back.
Soon it is planned to make an actual public release of the new SwOS version with bugfixes and new features.
