SwOS and Digest Authorization
The SwOS has some real good stats that can be delivered over a Digest Authorization with URI, but in testing, I’m having issue getting the Digest Authorization to work. Are there any requirements we should know about, for example, any requirements (say for example on the length and format of the cnonce) that MikroTik can provide to make it a bit easier?
Thanks,
TheWitness
The beauty of using CURL, is that you don’t have to figure too much out. Okay, I’m getting stats now. Just to parse is all. I can figure that much out.
How are you actually consuming this? What endpoints are you hitting?
