SwOS bandwdith limiting syntax
The wiki says the value of bandwidth limit is in bps… the field in the web interface is about 4 characters long.
I’m clueless as to what is the format.
Could it not be 10M for 10MBps … and 10K for 10 Kbps and 100M for 100 MBps…
What is it ?
F.
The input of the Bandwidth Limit text field is not limited by its size.
And if you do not want to enter many zeros, your described syntax is also a valid input.
Can I have some examples of the syntax …
What is the way of expressing 100 mbps ?
F.
You can write 100000000 or 100M, after refresh in web browser value become 100M anyway.
What are the other variants ?
Does 768K work ?
for 768 Kbps ?
Where is this documented ?
F.
