In this business, “no news” is never “good news”, so it would appear that Mikrotik has abandoned SWOS.
It has been over a year, almost 14 months, since 1.6 was released and there is no word on 1.7 or 2.0 or fixes to any of the outstanding issues/requests.
You have to understand that rb250gs is low-cost Gb managed switch so it doesnt fit to core net. I have about 100+ rb250gs and they are very good but only on the end of the network or in small networks.
So conclusion is you dont need newer fw, 1.6 is good.
The idea was good, except the 250GS was a disaster for VLAN usage. It is essentially useless in a VLAN environment as it lacks some very key basic abilities that should always be available in a VLAN environment. This was a HUGE mistake by Mikrotik. For the 250GS it is also a hardware limitation so there is no answer to the problem.
SwOS is a good concept, but it needs serious development. To me it is the equivalent of ROS 1.02 (If that ever existed)
I would like to see Mikrotik compete with Ubiquiti and their new line of tough switches.
Configurations I would like to see
8 port 10/100 with and without poe
8 port 10.100/1000 with and without poe
24 port 10/100 with and without poe
24 port 10/100/100 with and without poe
I would like to see the poe models have similar qualities to the RB750. I like that I can infact power the RB750 with poe and then power ubiquiti access points off the RB
The only thing I find lacking with the 750 UP is the ability to missuse the hardware as a switch and add vlan tags to ingress packets on the port level. If there is a way to do that please slap me silly and point me to a howto.
