SwOS version 1.13 released
**What’s new in 1.13:
*) allow to disable SFP port;
) do not disable SFP port if loss of signal is detected, some SFP modules
do not report it correctly;
) make autonegotiation work better;
What’s new in 1.12:
*) fixed problem - SFP port stops after ethernet port cfg change (RB260 only);
*) change default vlan mode on RB260 to ‘optional’;
*) fixed problem - SNMP worked even when disabled;
*) fixed problem - SFP autonegotiation setting was not saved (RB260 only);
*) fixed uptime to be correct;
*) fixed RB260GSP poe-out to work correctly after downgrade & upgrade back;
What’s new in 1.11:
*) added support for RB260GSP;
What’s new in 1.10:
*) allow to disable/enable auto negotiation on SFP port on RB260;
*) fixed problem - hosts tab stopped working if 0:0:0:0:0:0 was learned on RB250;
*) enable transmit on SFP port only when module with signal is detected;
*) fixed problem - port lock & lock on first did not work on RB260;
*) fixed problem - port full duplex setting was set for wrong port on RB260;
*) fixed problem - broadcast correct uptime to it’s neighbors;
*) fixed problem - port egress rate did not limit traffic properly on RB260;
*) fixed problem - sometimes board did not reboot after upgrade;
*) added vlan-id to static host table;
http://www.mikrotik.com/download
This version fixes 1Gbit ethernet autonegotiation with Cisco 3550 and improves compatibility with SFP modules which do not have DDM.
Any plans to add RADIUS authentication instead of local username/password?
Please update the wiki so the SwOS manual covers the PoE options in the “Link Tab” section for the RB260GSP.
This version break SFP link status reporting over SNMP. Module present, loss of signal detected but SNMP reports IF-MIB::ifOperStatus.6 = up(1).
Mikrotik : Why no topic about 1.14?
No info about new version on email.
What’s new in 1.14:
*) fixed RB260GSP poe-out;
Source: http://download.mikrotik.com/swos/changelog.txt
For 1.15 it would be great if an option to disables the LEDs permanently or partially (in accordance with a timetable) was added.
and allow to change port name and add vlan name. Maybe add some log with information port down/up - date/time?
+1
…and serial number and firmware version available over snmp.
