*) new poe-out sw version 2.18 - fix unintended poe-out state change;
*) new poe-out sw version 2.15 - increase initial power-on delay 1s->4s;
*) report correct uptime in neighbour discovery even after 18 hours;
*) report correct ifAdminStatus via SNMP;
*) report SNMP ifOperStatus Up for SFP port only when link is present;
*) extended SNMP contact info fields to 32 symbols;
*) added IVL option (independent learning) to VLAN entries;
*) report negative temperature properly;
*) report tx/rx power for SFP interface;
*) name can be assigned to each port;
unfortunately i can’t check this feature, because after upgrade i am not able to connect to 260GS via web interface, the browser just gets the “download” file
After the upgrade can not see SFP parameters and the SFP tab I get the message
INTERNAL ERROR:TypeError: Object doesn’t support property or method ‘log10’
After the upgrade is from strange reason stopped work SFP module.
By changing the SFP module started working and regardless of IE.
If you use windows OS in the business environment only reasonable to use IE.
If you have a suggestion for something useful that is not upgraded 2 times a week, I’m interested.
And as we know all web browsers are useless garbage.
Then I choose the least evil with the least problems.
Can we get https support added to the web interface? And maybe a RADIUS client for centralized authentication? The lack of even minimal security for the administrative interface is troubling…and it shouldn’t be hard to correct either of these issues…
