What’s new in 1.9:
*) fixed problem - RB260G wasn’t reachable over VLAN;
*) power down port when it is disabled;
*) fixed problem - logout did not work;
Why did not fix the problem please SNMP? SNMP me constantly DUDE falls at the switch.
I upgraded one of the 250 switches and it’s not working anymore!
I tried with a second one and the same happened.
The web interface is no longer working after upgrade!
Has anyone tried to upgrade to 1.9 and succeeded ?
Waiting for a quick fix from MIKROTIK!
Please give us a way to recover the damaged units after 1.9 upgrade.
Ben
This is what I get instead of the switch interface page:
max:32},def:1},{t:,def:1},{t:'staticbooXdr',invXdXdr',inv:],t:0t:0sep:':0xx:'D,tD,t:bools,id:'frumum,id:'vidl',max:4&z5]<bnmp=,def:1 nmp=,def:1 y%6d ,def:1 y%6d tons y%6d tonsiority%6d tonsiority'" tonsiority'"5sonsiority'"5s',$wdtnfo$s',Frsnfo$s',Frsnde',c$s',Frsnde',c[ACs',Frsnde',c[ACL',snde',c[ACL',url:'[ACL',url:'acu uu u$By:spri',maBy:spri',matup<~spri',matup<~.t,def:8}u<~.tMACu<~.tMAC Dst'',ress',t:ipMAC DstMAC Dst'',dn:'Iro::un:'Identun:'Identity bon:'Identity booi booity',t:str,idity',t:str,id:0ity',t:str,id:0[ D0[ D'},<mpe0x9royt'},<mpe0x9ro'},<mpe0x9ro "<mpe0x9ro "up'u0x9ro "up'},{ "up'},{n0n:' "up'},{n0n:'Pr"up'},{n0n:'Prio$s',Frsndn:'Prin:'PrioS tuple,S tuple,cnu P ta'},{t:num,id:'all P tuple,cnt:1uC6uC612u,.pwz3sxsep:'-
u
usep:'-
u
u
.+id+"')
u
u
u
u
"u"u"u""
u
u
"u"u"u""|(
u
"u"u"u""|( "u"u"u""|( !id:"u"u""|( !id:i"|( !id:id|( m:'42ttons} |',mattons} |',max:7C |',max:7CPV" P Proup'},{t:'staProup'},{t:'stat:roup'},{t:'stat:[{:[{t:mac,id:'sma;';'/',a:[{t:mac,id:psnde',cnt:1,la<r<refres,def:1},{trefres,def:1},{t:',def:1},{t:'statbobools,<~.tuple,pptlmp"z nv:0},{nmp"z nv:0},{note"z nv:0},{noter P nv:0},{noter P, P,c:'match'},{tP,c:'match'},{tic,c:'match'},{tics'tics',url:'!staAt]],foote[ Dst' uvu526tet |/-\ Bd t#Cdp uvutt:F$Mboo cu(:0$
`"u<t b, tddress tnk.p. },C_$<hare "on`{ D,t:bf``t,p'f5 <t b,<t b, t0mp"zm't,, ) v nD:`
yututl$>ta:[TV n!"|3cu( t"V nmaxX8Z"u"u"u"SPt0*0,nip *0,nip udp
t7*vocon:D:n ! u" nlo xY0`
y.cu(t@5 tU615s',""ip,By:
u
u
"u"u"ucu(c v"tmcu( v"tmcu(:0$mperatu[t:P"QT%z {ip'$tics',ur# %
!u$Mp `z!t@zxZut:B21AE4 us',,']},dho^3{|3 % tto"mr:!{t50,nip|} pt
.2Kd"!u$`z!t@zxZut:@21AE4 us',,{ :0,ro8U]reb0&oc.b:?n:?<~.tu&vocon:D:nd .c&1AE4 utl',maJtet |/rom8
1, (9= nmp(. "o$tl',mu]
l $tl',m%'f' s' t tet |/-\ B_Alltnk.p+$tl'D!Alltnk.p*l'|3Iu^ 5'},&tt, dipdp0* uu% s' t<~.tuW 5'},&]&tt, ^u_,0x5|
dp0,% , *tnv3t dscmax"`!4 ut[C $Zter:[{t:t:n',t tl',m~.cu( !"|3_'%
vsk',de<-zt-t:0setXzE51321q # yy S0[ D'vocon:i0S%,def:`
yC%,def:`
yS%
!uu[C $ZteuW 5'},&]&ttC0S%,def:" tU6+$},{n% tt:b ?hz cu( tU-"% P'cu( tU-"%| t+on:260 $
<S
dp0,rio',m$^tnk.p*t_ t+8U]re} m:'4^nlo^v5
Xp',S6
u$M6u]u*+$
t*t= A
(9tuple,c]u] { z{ t *-ttons},{t:'group ~ D0x0U536f66745D0x0U536f667452 P tuple,cnt:1,tu tuple,cnt:1,tuplAC SrBy:ip'(um,idbBy:ip'(um,idbools,(um,idbools,<~.tbools,<~.tuple,p<~.tuple,pro7uituple,pro7uip'},cpro7uip'},c',$oteuip'},c',$oter:[{tc',$oter:[{t!tf,$oter:[{t!tf,oteoter:[{t!tf,av y%6d tonsiorit35},35}tonsiority35}tonsiority'"5tonsiority'"5s'onsiority'"5s',Fiority'"5s',Frsn"5s',Frsnde',c[As',Frsnde',c[ACL'snde',c[ACL',url:3[ACL',url:'acu uMAC u$By:spri', u$By:spri',matBy:spri',matup<~.spri',matup<~.ttup<~.tMAC Dst'<~.tMAC Dst'',dtMAC Dst'',dn:'MAC Dst'',dn:'Id',dn:'Identity bn:'Identity boot booity',t:str,ibooity',t:str,id:ity',t:str,id:0[ t0[ D'},<mpe0x9r[ D'},<mpe0x9ro'},<mpe0x9ro "t<mpe0x9ro "upmpe0x9ro "up'}0x9ro "up'},{n "up'},{n0n:'P "up'},{n0n:'Priup'},{n0n:'PrioS0n:'PrioS tupleS tuple,cnu P tuple,cnu P tuu P tuple,cnt:1uC_uC612u,.pwz3C612u,.pwz3sesep:'-
u
usep:'-
u
u
u
u
"u"u"u""
u
u
"u"u"u""|u
u
"u"u"u""|( "u"u"u""|( !idu"u"u""|( !id: "|( !id:id|( |( !id:id|( !|( !id:id:'| || |',max:7CPV" |',max:7CPV" P Proup'},{t:'statroup'},{t:'stat:[*:[{t:mac,id:'sma;Priorit'/',a:[{t:m'/',a:[{t:mac,id:??>.<refres,def:1},<refres,def:1},{t::4095},{n:'?t:enm,D0xt:P"mp"z t:P"mp"z nv:0mp"z nv:0},{notter:[{t:'gz n!nv:0},{noter:[{t!tf,avln:0x0,lcbl:0x!"|+id+"536"pwd."Ud:'42'"+id+"');";add(liPt_$load();}{ S0x0functiosip'},{ot:num,id:'sipm',maIP Src',t:tuple,c}]},{n:'IP Dst',t:m,id:'D0,a!"pwd."Ud:'42'"+idu( !id:'pr!"`prt',rol',t:'gr},{n:'Mn:'IP AdVLAN ID'$:0x0},.pwd.b:{pwd!`vid',ro4.pwd.b:{pwd:'42656"|( !id:id:'"%!0},.){if(activeRe"},.pwx!*",Ports"{ VLAN ID',cnt(um,id:'vid',ro)(Z1},{n:():{id:'foa:[{t:(ctivate('"+idCPV nr();post("/log'ip'},{nv:b){s',FroUt:2,P<s',FroUt:2,P<nv>b[<s',FroUP<s',FroUt:2,P<S" ` ,0x00,0x00], `untaggeS0x0functios0x0functiosipfun00000u!tf,a!tf,av6d612033e 0xeS&z5spap2:0x1d00],v,b){retu_$l!bou( !Prioriprtt',t:boPu&z5]<bJ!ro:1},{!"&eRut ""dscp'"&eRut ""dscS!t:0x0,imr:0x0,ur'},{},J!ro:1!*",Pf,avlnmirmp:{id:uoter:[Jvlan.b:!d61206d612033d61203Nnohead:1,pro!ead:1,props:[{"536b){s',FroUt:2cs',FroUt:2,P<owe%fresh:500<ple,sep:':mac,id:%,ro:1,so0num,id:'dp
e 0x00,0x00,2:num,id:'d"u 6e536f6674527t\m:'42656e53act Info',t:s#Info',t:str,cn$"
have you tried a power-off, wait 5-10 seconds and then power-on of the rb250GS ?
I have had this same issue with one of my rb250gs with the 1.8 firmware, i did the power off thing and all worked again, i have had the same cryptic output of the webinterface.
But you should be have a second device as backup, if things go wrong.
I will wait with the 1.9 update on my 250 and 260 switches, as i need them ![]()
EDIT: Upgraded both switches to 1.9 (RB250GS and RB260GS, works on both fine)
Ronny
That cryptic output is a cosmetic problem which can be observed during changing between old and new Web GUI design. Power cycle fixes it.
Will you ever fixed a problem with the mode 1Gb Ethernet?
Indeed, when I switch ports at 1Gb so I have problems quickly transfer data. The more I latency and the less transmitted. Maybe speed is 100Mb already unreachable after 10ms delay. After 10ms delay will read about 35MB.
It’s always interesting when I switch to 100Mb ethernet ports so the problem does not occur. Even after I was able to 10ms measured around 100Mb.
I suspect that the problem is in the fact that 1Gb makes great peaky, it increases TCP window size. Switch problems with it. Packets about probably does not manage cleared. I do not know if it is not a hardware limit switches. Perhaps the small stack memory.
I use SW OS 1.8. Worst worked version 1.6. There was ryhclost awful. In version 1.7 and 1.8 the problem is improved, but still that’s not it.
You can do this remotly - http://ip_address/reboot
becs - when problem with “broadcast strom control” missing will be fixed?
Hello!
Unfortunately my RB260GS SwOS does not reinstalling from net…
I followed the instruction athttp://wiki.mikrotik.com/wiki/SwOS#Reinstall_SwOS_firmware
ACT led keeps rapidly flashing (reset does not help).
Is there anything I can do, or RB260GS is dead, and should be returned to distributor?
If ACT led keeps rapidly flashing, it means it is not dead.
It also means RB260GS is waiting for firmware file but somehow cannot receive it from the TFTP server.
Make sure RouterBoard router acting as TFTP server is configured exactly as written in manual. DHCP server must have “bootp-support=dynamic”.
Sorry maybe I should open new topic, but …
I have bought myself two RB260GS switches and one of them did not recognize SPF (S-31DLC20D) …
So I got advised to update the firmware and here it all goes down 'cos I downloaded FW for RB250… and my bad is going on.
I do not have RouterOS or any other mikrotik hardware …
My LAN are only Microsoft machines … on untangle router…
What I would like to know how to “netinstall” (bootp + tftp + dhcp) from Windows 7 x64.
Which software do I need and how to perform this re-installation of SwOS?
And yes - ACT led keeps rapidly flashing (reset does not help).
Thank you.
