SwOS version 2.7 released!
Sorry, its nice to see new features, and IGMP snooping on switch like this, but where did the uptime display go ? Its useful in debug on remote locations.
So far no multicast in 2.7 (RB260GS).
In regards to the IGMP discussion with the CSS326 & SwOS 2.7, I too need to know more information regarding it’s IGMP/Multicast feature support. I have seen where IGMP support was included and it does appear to be working for us. I have several multicast channels hitting the up link port (24) and see 24Mbps in the Stats tab. For each STB connected to an individual port, I only see the ~5Mbps being flooded to that specific port as it should be based on the multicast channel the STB is tuned to. However, to get this to work, on the upstream switch, which is a Cisco configured with pim sparse-mode, I had to issue static-group IGMP join statements. Simply tuning the STB up/down would not “join” the channel. Is there any deeper detail on the IGMP processing that the CSS326 and the SwOS 2.7?
I can mirror the port and collect packet captures if needed.
I’m not sure if there were several versions I missed or if you guys just jumped pretty far, but are there any concerns in upgrading from 1.17 to 2.7 directly?
I’ve made a jump from 4.17 to 5.20 on an RB433 and bricked it 140ft in the air. It required a bootloader update that I didn’t apply as I skipped that version. Netinstall brought it back, but I’d rather prevent such issues by asking first in this case.
It is not possible to install SwOS version v2.X on devices with SwOS v1.xx due to hardware differences.
Is anyone in Mikrotik team aware of multicast problems since 2.5 ?
So far nobody from Mikrotik gave any comments regarding that issue.
http://forum.mikrotik.com/t/rb260gs-and-television/110112/1
http://forum.mikrotik.com/t/css106-5g-1s-fw-2-6-multicast-not-working/114713/1
Have to stay on 2.4 so far.
Ask support@mikrotik.com
I’ve just bought CSS106-1G-4P-1S. Upgraded it immediately to 2.7.
Problem: it auto-negotiates 100Mbit Full to the following devices:
  • CAP ac
  • SXT Lite5 ac
  • Samsung TV
All of them are 1Gbit Full rated. Forcing it does not help.
Auto-negotiate works fine (1Gbps) for the following:
  • SXTsq 5 ac
  • Laptops
What is going on? This is NOT a cable/RJ45 issue as I have tested everything (direct cable, cable via socket, CAT6, Cat5e, shielded, non shielded, 3cm, 5m etc..)
Can I power up an IP camera that supports 802.3 af or 802.3 bt from the css326 switch?
For me BCS camera don’t work. I see current too low.
Wysłane z mojego TA-1021 przy użyciu Tapatalka
Works for me.
Version 2.8 of SwOS has been released:
http://forum.mikrotik.com/t/swos-version-2-8-released/121733/1
