SXT 2nD r2 -need to create bridge beetween two other routers
Hi. (I’m sorry for my English)
I’ve got some problem(read to the end)
I’ve got two routerboard SXT lite2 (SXT 2nD r2), and we are in need to create a Wi-fi bridge with both of them, between two home routers.
Point A (where is ISP input) router D-link DIR-300 NRU B5 (f/w 1.4.9) and
Point B (where also in need of Internet access) and router are TP-Link model: TL-WR740N (ver.4.21)
Both point in need of Internet from one ISP
What is need to be created:
  1. ISP PPoE entering at point A and going to DIR300 WAN port, (what is exactly on now )
  2. SXT lite2 (giving name AP1) connecting to Ethernet port DIR300 where getting IP address from DHCP and Internet through NAT of DIR300
  3. then AP1 making a bridge with second SXT lite2 (giving name AP2) via wi-fi
  4. AP2 giving an Internet to TP-link WAN port
  5. TP-link giving an Internet access to all client it served
    I’ve updated ROuter OS to ver. 6.1 and firmware to 3.08.
    And have done some job and get stuck at point 3 may be 4, because I cannot fully check out point 3.
    I’ve been using Quick set to configure both of them.
    AP1 configured in P2P bridge, as server/AP with nv2 and 2Ghz only-N, address acquisition DHCP, source Ethernet
    AP2 config in P2P bridge as client, have founded wi-fi with ssid and connected to it.
    But then is a stuck
    Please help configure it to the end
On both Routerboards you should create a bride and put both the wlan and ether interface into that bridge.
Made the adjustment based on the info from this article:
http://www.wispforum.net/entry.php?5-How-to-Connect-two-Mikrotik-SXT-5D-s-In-Bridge-Mode-Part-I
http://www.wispforum.net/entry.php?6-How-to-Connect-two-Mikrotik-SXT-5D-s-In-Bridge-Mode-Part-II
Signal strength -33 dB
Testing bandwidth both way give a 45 Tx/ 50 Rx Mbp. Test was performed from DIR300, by connecting to AP1 and sending to AP2. Then test both direction.
I’ve setup bridge, and on the second AP2 my notebook get an IP address, mask, gateway, DNS from AP2 but internet doesn’t work.
If I try ping gateway, there is no ping.
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.90: Destination host unreachable.
So I’ve reset and remove configuration.
Than on WLAN do enable wlan, set mode bridge,band 2Ghz mode N only, set SSID and frequency, Wireless protocol to nv2, set country Ukraine. Then on HT tab mark all chains 0 and all chains 1. On Tx power tab, change tx power mode to card rates, set Tx power to 1. On NV2 tab set cell radius to 10 and mark security with entering a key.
Than go to Bridge, create bridge1 and set protocol mode to rstp. than on bridge port tab created port ether1 to bridge1, and wlan1 to bridge1 with default sett.
Then in IP DHCP client create client to bridge1.
Then doing the same to second AP2, except set mode wlan to station.
What anything else I need to get my notebook (firewall disabled on it) get ip addresses from Ethernet AP2 and go to the Internet?
Trying make setting like explained in this article(but protocol is nv2):
http://wiki.mikrotik.com/wiki/Bridging_Networks_with_SXT
My notebook on AP2 ethernet port connected get ip addresses, and internet is working.
But now IPTV doesn’t work. What the problem in? Do I need to setup a multicast?
