I was wondering if someone could confirm that the following configuration can be implemented.
I have to build this network were i have to send the signal 200 m away by radio, and i was thinking of using 2 SXT 5 ac.
the access gateway is a RB3011UiAS-RM it will be used as hotspot controller for 2 vlans, one sxt 5 will be connected by poe to the RB3011UiAS-RM and the receiving SXT5 on the other side will be connected to an wAP ac with dual ssid for the two vlans.
Before bying all this components i just wanted a confirmation that this can be configured to work like this.
Thanks for the reply.
Would it be possible to catch the reveiving STX 5 and the AP following it, with CAPSMAN, or does it work only on wired connection?
ted - connecting two remote networks together and passing all 802.1q tagged vlans does work and it works very well. I have dozens of 802.1q tagged vlan links. Whan you need to do is to build an AP and a remote WDS client.
Note - It also works if you build dual links and let spanning tree do it’s work.
