SXT 5 Lite problem
HI. Such a problem. Install SHT 5 lite. Does not change the transmitter power. Changed tab TX Power - card rates. Updated to OS 6 .1. No first name. The tab Curent TX Power unchanged. How to fix this problem?
use - all rates fixed. It works. Card rates is not supported in this chipset
Thank you for help.
leave at default if you are not sure about what setting to set to be safe
