sxt 5hnd upgrading
please i updraged firmware 4.4 that came with sxt to 5.5,but after the upgrading the cpe started to be rebooting itself after with 2minutes and attempt to downgrade back to version4.4 proved abortive. :astonished:
so i thought of getting the ver4.4 firmware and install it on the cpe.please will it work and i need its link? thanks
Had something similar. Made use of netinstall and re installed 5.5. This fixed the problem. Might work for you as well.
thanks,that is what we did.
