I can’t figure out what is happening to my SXT 5HPnD. It is powering properly (Power led is green).
I can hear it beeping at boot after a few seconds however it does that a few times like it is restarting…
The User led sometimes gets green as well but not long.
I tried to reset it a few times using the button or using a screwdriver but that didn’t helped.
The main problem is that it can’t retrieve an IP from any DHCP server.
It used to work with a static IP address which is not accessible anymore.
From another mikrotik router connected to it which is a DHCP server, here is the log :
10:25:47 interface,info ether3-slave-local link down
10:25:54 interface,info ether3-slave-local link up (speed 100M, full duplex)
10:25:58 interface,info ether3-slave-local link down
10:26:01 interface,info ether3-slave-local link up (speed 100M, full duplex)
10:26:02 interface,info ether3-slave-local link down
10:26:05 interface,info ether3-slave-local link up (speed 100M, full duplex)
10:26:12 interface,info ether3-slave-local link down
and this continues for ever…
Any help would be greatly appreciated.
Thanks in advance.
Julien.
