SXT-5HPnD
http://routerboard.com/RBSXT-5HPnD
Now we are moving.
Waiting for SEXTANT with the same output power ! :smiley:
Mikrotik,
23dbi antenna and metallic enclosure please. Fedup with plastic. 16 dbi with that much power is a low requirement. High antenna gain is needed more. Sextant is a bit short.
This device is the best to work with omnitik. When should we expect to get from our distributors?
How is it best for ominitik?? compared to the usual SXT
Agreed, higher gain antenna and lower beam-width is better than using more power to reach the distance you require. This will destroy a mast on default tx power, if used for a PTP link.
I prefer narrower band then high power.
Curious to see how it performs though.
Yes, I agree strong too. The best amplifier is good ANTENNA !!!
I don’t see where this hp sxt would fit. Could someone give me a hint?
P2MP is out of question me think..
Distributors should already have it! Email them and ask.
If not for PtM, then for short PtP links. 10Km should be possible.
can I use this device as a Acces Point or as a Hot-Spot ?
You could, but it has a narrow beamwidth directional antenna, which is made for a different purpose. clients would all have to be facing the SXT unit directly.
For accesspoint and hotspot, I recommend a similar device, but with the appropriate type of antenna, the OmniTIK: http://routerboard.com/OMN5HnD
Actually I already have this device as gift from my friend so I just want to know how can I use this device :slight_smile:
I work in a saturated area, so I also prefer narrow beamwidth and metallic enclosure to minimize interferences.
Antenna dBi better than radio dBm!
i prefer omnitik with higher power
+1
