On SXT ac (ROS 6.18) current TX power display value is all the time 0dBm. Is this due chip change (Atheros->Qualcomm) or different problem?
you must activate first the wlan ![]()
I have active link with only AC, but txpower is always 0.
Sent a supout.rif last week. Should be a known bug.
I see the same here.
Also the signal on a 3,5 km link is very bad. So I asume that really no tx power is being used.
I have tried all settings that I found. No change.
any udate about that? RB911G-5HPacD and RB922UAGS-5HPacD the same problem with current tx power…
I think it’s related to all “ac” chipsets. I have miniPCI cards R11e-5HacD with same situation, there is nothing in the “Current Tx Power” tab.
This is still happening with RB911G-5HPacD and RB922UAGS-5HPacD under ROS 6.34.4 w/ firmware 3.31.
Same situation with RouterBOARD 952Ui-5ac2nD
Sent from my Lenovo K50a40 using Tapatalk
