SXT can not connect to LANcom Router
we cant connect with a SXT to a LANcom Router. WPA2 with aes is activated, but we can not connect, what can we do here. any ideas? Other devices for exsample ubiquiti works fine.
regards
Try more explain the situation:
Configuration Lancom router
Model enz
This may be an incompatibility problem.
Always use appliances of the same brand.
Some devices of different brands can not communicate with each other.
we use a lancom 322agn dual al AP and must connect with a MT SXT. LANcom was configured with WPA2 aes/tkip.
SXT can only connect in station mode and group-key psk to LANcom AP, but we can not login with 3 PPPoE connections over this connection.
We would youse station bridge mode, but with this we can´t connect to ap, we have test with and without security, sxt can´t connect and jump the channels. we do not have any ideas, but other devices for exsample a ubiquiti ns can connect fine with wpa2 aes and a smart phone can connect fine too with wpa2 aes. Only sxt can´t connect and we have no idea,
do you have abny ideas for us?
regards
I think SXT is not compatible with the Lancom.
Both devices can’t not good communicatie with each other
