SXT client + 802.11a AP
Hi Guys…
I need try this :
433ah + r5h + setorial 17db H (AP PtMP MODE)
SXT (CLIENT MODE)
How to do the sxt antenna orientation and ROS config in this case ??? (one antenna)
many tks…
Normal, as it is. Default is H, if you turn it 90 degrees then is V.
