Dears,
I have question about compatibility of UBNT with( Airmax ON) product as AP’s with Mikrotik SXT as CPE(PPPoE client)
Anybody try this combination???
Please advice…
Thank you!!!
Airmax and NV2 are proprietary protocols. Airmax is Ubiquity only, NV2 is Mikrotik only. If you have either enabled, the other brand equipment cannot connect.
Thank you!!!
Just to be clear, if you are not using Airmax, NV2 or Nstreme they work together just fine.
Yeah, and both protocols are TDMA based, so who knows how much they actually differ
it’s a good thing ubiquiti exists. It pulls up mikrotik to competition ![]()
