sxt ether port showing down in log every 1-2 min
hi guys
last two days i am facing a problem with sxt 5nd r2(5.26) .
they are in point to point bridge mode (wds) and every 1 or 2 min ap side ether port
going down in log .
can anybody tell me the why this is heppning and what is the reson.
is there any body faceing with same promlem.
thanks and regards
on how much distance that from each other.
Stay the wireless link up?
how long is the ethernet cable?
Please upgrade the RouterOS to v6.7 and then upgrade the Routerboard firmware to the latest available.
Then check again.
Also try to replace the poe injector if you have a spare one.
probably it is the RJ45. Change them and see what happen. Already have this problem on my own…
