I have an SXT that looks like the Ethernet port is dead.
Light on the connected switch shows it is connected but neighbour can’t see the unit.
Since terminal session is not possible tried the netinstall procedure with the screwdriver method (10secs press - release after led stop flashing) but netinstall is not picking up the unit.
Is there anyway the board can be revived or terminal’d in by the usb connection?
Or can this board be the next one on a series or rb’s that have a dead Ethernet port developed just in the middle of being productive?
wireless is not accessible? by the way, the netinstall can’t be launched with screwdriver method, that’s only for system reset. netinstall launhes with the button behind the door.
You’re right, its not the screwdriver method but the pressing of the reset button. I’ve done it that way.
And no, after a reset (which is the first thing you usually try when a board fails) back to factory default the radio is switched off.
So I think this is yet another unit with a failing Ethernet that I have to send in under RMA…
I would request Mikrotik to sort out ethernet port problems on both SXT & Groove.. I have lot of devices which power on …give booting beepps… show as connected but won’t show up in WINBOX & no ping replies from the units.
How do I fix them…I gave some of them to my vendor but he took 3 months to get it from RMA.
mIKROTIK PLEASE LOOK FOR A DISTRIBUTOR IN INDIA who can maintain logistics for RMA.
i have tried everything possible. reset by shorting. pressing the button while the unit boots up. used factory crimped cables to test if there may be crimping issues. changed power adapters and poe’s. nothing helped. most distributors r selling mikrotik gear by clearly saying that they cannot give warranty. they give excuse of logistic problems and customs clearance etc.
with warranty takes 3 months for replacement or even they are reluctant to give it for replacement and have tied up with some local guy to have it repaired or tweaked. we are paying the extra buck to get products with warranty. i don’t want to take names but I have tried each one before settling for one distributor and the volume of orders we are placing with him is far higher than any other ISP in eastern india.
i think i have discovered some issue with the mikrotik ethernet ports on sxt’s, grooves, 711’s and the recent 911’s.
Normis needs to seriously take this up.
Earlier boards had pins going into holes on the board. This was a much stronger hold.
Recently they have started superficial soldering which often loosens when cables are plugged in, specially with cables these days coming in all sorts of thickness.
Also the inside of the ethernet port connector(the pins inside) moves back and forth. i had a broken connector in my hand and noticed it.
What is this for NORMIS??
If the pins have so much movement (almost 3-5 mm back and forth) space these will have the tendency to loosen from the kind of superficial soldering u have. Is it some kind of tactics to have the sales high???
I have to put this on display at the recent MUM.
I don’t know in general but indeed we had some boards were the ethernet interface came loose very easy the first time we plugged a cable. Some times due the outside box a ethernet cable needs some force to get it in front of the port before it slides in and yes, in doing so some came off very easy… not good…
