SXT G-5HnD - Sector
SXT G-5HnD praised as 25 Degree Sector.
This is a bad marketing joke or shouldn’t I laugh?
A Sector should have:
  • good Front to back ratio as I expect to mount more than one sector an a site
  • Small vertical beam to give a good pattern on horizontal
Of course I can use it as AP for a small amount of users within the beam but this
can be done with every MT driven Antenna with a Level 4 License.
You should insist on proper installations to get good results with MT-Gear. Selling this in
this way you get a lot of NV2-Disconnect threads.
Correct me if I am wrong and this device has a shield kit and a special TX-pattern.
for small deployments this device is ideal.
for large deployments a huge amount of rf interference is to be expected.
Not ideal. It may work great and then suddenly bad. The SXT gets a lot
of signal from behind. If it’s your’s or any other Wlan flying around.
If MT integrates a metal shield this would change things. But better would be to
do a real sector antenna with a SXT attached behind in a metal housing.
