Sxt G-5HPacD not 10 Mhz channels
Hi all,
Wanted to use Sxt G-5HPacD with 10 Mhz channels. But in the channel-list is no valid 10 Mhz channel? Is this normal? Does someone have an solution? Thanks in advance.
hk :smiley:
Use in Frequency Mode = superchannel
Ac doesn’t support 10mhz channel. Don’t you read official product webpage?
Mine have 5 and 10Mhz but I didn’t try if it works or not.
Hi all,
Thanks for your help. AC-Products do not have 5 and 10 Mhz channels supported, but it is still part of Routeros in this product. Should be disabled by MIKROTIK.
HK
That’s true. Offering not valid values is amateurish.
If it works between 2 Mikrotiks just call it legacy mode and see it as additional feature.
