SXT/LHG LTE KIT
Ref the new LTE kits with two sim card slots.
will system connect to first available network, and if that fails (later on), will system connect to the other network?
regards
john
https://wiki.mikrotik.com/wiki/Dual_SIM_Application
Thanks - that helps me :slight_smile:
How did you mark my post solved? I can’t find any such feature?
hi
i the upper right corner of the post you will find 4 icons - one of them toggles solved/unsolved.
well only yesterday i discovered the feature :slight_smile:
again - thanks for your help
