Sxt lite 5 unable to connect to ap
My sxt lit 5 was unable to connect to access point. Signal of ap is -61 dBm In which I want to connect. After select the ap when go to connect to that ap first it shows disabled and then immediately shows searching network and stuck on it . no result.the waywe tried to other ap result same .device is update to newest 6.34.2 router os. .
So is my heartiest request to the forum member as I am nobb so pls help sir
it’s no possible to find out your problem except you post your wlan1 configuration and also tell us what is your AP device ?
Bro my ap device is omnitik 5 uhnd and wlan1 configuration I can’t remember now
There can be many reasons; first check the log of the AP and client to get more clues. Activate wireless debug logs eventually.
It can be a misconfigured security profile
It can be a misconfigured country, so client doesn’t want to use the AP frequency
It can be a connect-list rule
It can be an access-list rule
etc
etc
so copypaste AP AND client configuration and logs
Noib what u point out alright but lot other sxt lite 5 is connected in same ap they r not face the problem. In my device license label is 3 and ap license label is 4 .and other technical help for a nobb quite difficult
How to activate wireless debug mode in router is? And access point log file it is not in my hand if provider ready to to share with me then its ok
Go to system/logging and add a log rule with topics “wireless” and “debug”.
