Strange one. Got few of this Lite units. They do not want to associate to AP. In log it say
“failed to connect , on 5580000 not allowed”
and also on some
“failed to connect , on 5300000 not allowed-too many clients”
Have on average 30 users connected using this AP’s. Give this message for eight AP’s.Thought it might be OS 5.22, upgraded to OS 6.7. Same problem. The AP’s is RB 433 with OS 5.26 installed. Could get it to associate with link 10 km away. Also RB433, only change, running OS 5.21. Tried with second SXT light. Same problem. Any ideas or suggestions?
please upgrade the AP and the Clients to RouterOS v6.7 and then try to resets the wireless interface configuration by using such command:
/interface wireless reset-configuration wlan1
After that configure your AP and your clients and check again if you still see the problems with connection.
HI. Upgraded both to OS 6.7 and reset to client to default and set up again. Does not want to associate with these AP’s. However got it to associate wit a PTP link that is about 10km further and -83b signal. The problem though is that the AP is RB433AH with two RB52 HN radio cards on each. The PTP is exactly the same equipment and settings as AP’s exept for frequency. Have got quite a few of these SXT Lites running on the above mentioned AP’s.
Is only the last batch that has this problem now. Only difference i could find between the old and new batch SXT is that the old functioning batch had OS 5.25 pre installed and the new batch 5.22, letting me believe it might be older stock. Have me strummed.
Attached capture of client log if it might help. Also default authentication and forwarding is enabled on AP’s. The not allowed is the four AP’s with line of sight the client, about 2km at about 70db when scanned.
could you check the AP logs what does they report?
Could you do export compact from the /interface wireless menu from AP and the client and past here?
No info is displayed in AP log when client try to connect.
The AP not associated to export.
# jan/10/2014 14:18:25 by RouterOS 6.7
# software id = VWY0-E9UM
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n country="south africa" \
disabled=no frequency=5580 ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 \
mode=ap-bridge ssid=A3 wireless-protocol=nv2
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
band=5ghz-a/n comment="AP3b vaste 90deg" country="south africa" disabled=\
no frequency=5540 ht-rxchains=0,1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-\
3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,m\
cs-15" ht-txchains=0,1 l2mtu=2290 mode=ap-bridge name=wlan3 ssid=A3b \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps \
/interface wireless manual-tx-power-table
set wlan3 comment="AP3b vaste 90deg"
/interface wireless nstreme
set wlan2 enable-polling=no
set wlan3 comment="AP3b vaste 90deg" enable-polling=no
set [ find default=yes ] eap-methods="" group-ciphers="" \
radius-mac-authentication=yes unicast-ciphers=""
add authentication-types=wpa2-psk eap-methods="" group-ciphers=tkip mode=\
dynamic-keys name=encript radius-mac-authentication=yes \
supplicant-identity="" unicast-ciphers=tkip wpa2-pre-shared-key=\
Lv6141536dM
/interface pppoe-server server
add authentication=pap default-profile="AP3 profile" disabled=no interface=\
wlan2 one-session-per-host=yes service-name="A3 PPPoE server"
add authentication=pap default-profile=profile1 disabled=no interface=wlan3 \
service-name=service1
/interface wireless access-list
add comment="Jacquis Esterhuizen" mac-address=00:30:4F:*:*:*
add comment="Annelie Agenbag" mac-address=00:0C:42:05:*:*:*
add comment="****Benna Lubbe" mac-address=00:0C:42:*:*:*
add comment="Derick van Eden" mac-address=00:0C:42:*:*:*
add comment="James Sedling" mac-address=00:0C:42:*:*:*
add comment="Hansie Hansen" mac-address=00:0C:42:*:*:*
add comment="Andre Mosterd" mac-address=00:0C:42:*:*:*
add comment="*****Ralph Christie" mac-address=00:0C:42:*:*:*
add comment="Stix Pieterse" mac-address=00:0C:42:*:*:*
add comment="Base Link" mac-address=00:0C:42:*:*:*
add comment="Fia Veljoen" mac-address=00:0C:42:*:*:*
add comment="Richard Heyman" mac-address=00:0B:6B:*:*:*
add comment="Stephan Khun" mac-address=00:0B:6B:*:*:*
add comment="Barry Maritz" mac-address=00:0B:6B:*:*:*
add comment="Ettienne Liebenberg" mac-address=00:0B:6B:*:*:*
add comment="Christiaan Minny" mac-address=00:0B:6B:*:*:*
add comment="****Bennet Voster" mac-address=00:0B:6B:*:*:*
add comment="Hennie Verwey" mac-address=00:0B:6B:*:*:*
add comment="Base wireless" mac-address=00:0C:42:*:*:*
add comment="Happy Koorsen" mac-address=00:0C:42:*:*:*
add comment=Afrideca mac-address=00:0B:6B:*:*:*
add comment="Riaan Visser" mac-address=00:0C:42:*:*:*
add comment="****Johan Schoultz" mac-address=00:0C:42:*:*:*
add comment="*****Flip Botha" mac-address=00:0B:6B:*:*:*
add comment="****Pier Posthumus" mac-address=00:0C:42:*:*:*
add comment="Louis Shop" mac-address=00:0B:6B:*:*:*
add comment="Louis Van der walt" mac-address=00:0B:6B:*:*:*
add comment="Rita van Vuuren" mac-address=00:0C:42:*:*:*
add comment="****Nicky Swiegers" mac-address=00:0C:42:*:*:*
add comment="Louis van Niekerk" mac-address=00:0C:42:*:*:*
add comment="Dries Nel" mac-address=00:0C:42:*:*:*
add comment="Francois Bezuidenhout" mac-address=00:0C:42:*:*:*
add comment="Tabo Tamba" mac-address=00:0C:42:*:*:*
add comment="Leonard Verster" mac-address=00:0C:42:*:*:*
add comment="****Michal Moor" mac-address=00:0C:42:*:*:*
add comment="Johan Barnard" mac-address=00:0C:42:*:*:*
add comment="Christiaan Minni" mac-address=00:0C:42:*:*:*
add comment="****Sido Sampson" mac-address=00:0C:42:*:*:*
add comment="*****Johan Smit" mac-address=00:0C:42:*:*:*
add comment="Annemarie Jonker" mac-address=00:0C:42:*:*:*
add comment="****Francois Botha" mac-address=00:0C:42:*:*:*
add comment="****Dup du Plessis" mac-address=00:0C:42:*:*:*
add comment="****Ronald Bloem" mac-address=00:0C:42:*:*:*
add comment="Piet Kotzee" mac-address=00:0C:42:*:*:*
add comment="****Piet van der Merwe" mac-address=00:0C:42:*:*:*
add comment="****Ditk Uys-Beeslaar" mac-address=00:0B:6B:*:*:*
add comment="****Johan Smit" mac-address=00:0C:42:*:*:*
add comment="****Kobus Maritz" mac-address=00:0C:42:*:*:*
add comment="****Chrisjaan Minnie" mac-address=00:0C:42:*:*:*
add comment="****Richard Pretorius" mac-address=00:0B:6B:*:*:*
add comment="****Richard Pratorius" mac-address=00:0B:6B:*:*:*
add comment="Danie Lombaard" mac-address=00:0C:42:*:*:*
add comment="Japie Lombaard" mac-address=00:0C:42:*:*:*
add comment="Heinrieg Heinlen" mac-address=00:0C:42:*:*:*
add comment="Edison Matingwe" mac-address=00:0C:42:*:*:*
add comment="Max Fabio" mac-address=00:0C:42:*:*:*
add comment="Gillis Plaaitjies" mac-address=00:0C:42:*:*:*
add comment="Jaco Bosshof" mac-address=00:0C:42:*:*:*
add comment="Pierre de Villiers" mac-address=00:0E:8E:*:*:*
add comment="Dan Mc Carthey" mac-address=00:0E:8E:*:*:*
add comment="Marius van Niekerk" mac-address=00:0C:42:*:*:*
add comment=Rahoel mac-address=00:0C:42:*:*:*
add comment="Richard Wolstenholme" mac-address=00:0C:42:*:*:*
add comment="Frans Bredenham" mac-address=00:0C:42:*:*:*
add comment="Falkie Swart" mac-address=00:0C:42:*:*:*
add comment="Atie Venter" mac-address=00:0C:42:*:*:*
add comment="Henco Daubern" mac-address=00:0C:42:*:*:*
add comment="Pieter van Rensburg" mac-address=00:0C:42:*:*:*
add comment="Anette Boshoff" mac-address=00:0C:42:*:*:*
add comment="Jaco le Roux" mac-address=00:0C:42:*:*:*
add comment="Rudolf Steenkamp" mac-address=00:0C:42:*:*:*
add comment="Hendrie Cloete" mac-address=00:0C:42:*:*:*
add comment="Jan Erasmus" mac-address=00:0C:42:*:*:*
add comment="Mike Somerset" mac-address=00:0C:42:*:*:*
add comment="Wayne Saaiman" mac-address=00:0C:42:*:*:*
add comment="Wilco Engelbrecht" mac-address=00:0C:42:*:*:*
add comment="David van Vuuren" mac-address=00:0C:42:*:*:*
add comment="Mandla Mahlangu" mac-address=00:0C:42:*:*:*
add comment="Jaquies Esterhuizen" mac-address=00:0C:42:*:*:*
add comment="Samuel McCammond" mac-address=00:0C:42:*:*:*
add comment="Keitumetse Monocho " mac-address=00:0C:42:*:*:*
add comment="Johan Shoeltz" mac-address=00:0C:42:*:*:*
add comment="Madelein Basson" mac-address=00:0C:42:*:*:*
add comment="Jacques Fourie" mac-address=00:0C:42:*:*:*
add comment="Bertus Strauss" mac-address=00:0C:42:*:*:*
add comment="Fransouce Besuidenhoud" mac-address=00:0C:42:*:*:*
add comment="Johan De La Rey" mac-address=00:0C:42:*:*:*
add comment="Schalk De Waal" mac-address=00:0C:42:*:*:*
add comment="Hennie Verwey" mac-address=00:0C:42:*:*:*
add comment="Alex Flemming" mac-address=00:0C:42:*:*:*
add comment="Dough Blight" mac-address=00:0C:42:*:*:*
add comment="Kariena (Plaas)" mac-address=00:0C:42:*:*:*
add comment="Adriaan van der Merwe" mac-address=00:0C:42:*:*:*
add comment="Manus Bothma" mac-address=00:0C:42:*:*:*
add comment="Sido Sampson" mac-address=00:0C:42:*:*:*
add comment="Stein Wessels" mac-address=00:0C:42:*:*:*
add comment="Willan Cloete" mac-address=00:0C:42:*:*:*
add comment="Steve Witbooi" mac-address=00:0C:42:*:*:*
add comment="Kobus Maritz" interface=wlan3 mac-address=00:0C:42:*:*:*
add comment="Richard Pretorius" mac-address=00:0C:42:*:*:*
add comment="Nickey Swiegers" mac-address=00:0C:42:*:*:*
add comment="Christo Lensing" interface=wlan3 mac-address=00:0C:42:*:*:*
add comment="Kobus Fleming" mac-address=00:0C:42:*:*:*
add comment="Andre Castelyn" mac-address=00:0C:42:*:*:*
add comment="Johan Theron" mac-address=00:0C:42:*:*:*
add comment="Daniel Du toit" mac-address=00:0C:42:*:*:*
add comment="Stephan Maritz" mac-address=00:0C:42:*:*:*
add comment="Jhon Shouwn" mac-address=00:0C:42:*:*:*
add comment="Robert Marshall" mac-address=00:0C:42:*:*:*
add comment="Juan-Pier Vos" mac-address=00:0C:42:*:*:*
add comment="Olebogeng Moribisi" mac-address=00:0C:42:*:*:*
add comment="Mellie Grobler" mac-address=00:0C:42:*:*:*
add comment="Sonita Hilbert" mac-address=00:0C:42:*:*:*
add comment="Lionel Links" mac-address=00:0C:42:*:*:*
add comment="Manny Shepherd" mac-address=00:0C:42:*:*:*
add comment="Rishawn Stanley" mac-address=00:0C:42:*:*:*
add comment="Jacques Seaman" mac-address=00:0C:42:*:*:*
add comment="Nico Baard" mac-address=00:0C:42:*:*:*
add comment="Norman Riet" mac-address=00:0C:42:*:*:*
add comment="Bennie Fortuin" mac-address=00:0C:42:*:*:*
add comment="Seppie Dercksen" mac-address=00:0C:42:*:*:*
add comment="Bennna Lubbe" mac-address=00:0C:42:*:*:*
add comment="Zillian Enslin" mac-address=00:0C:42:*:*:*
add comment="Thomas de Toit " mac-address=00:0C:42:*:*:*
add comment="Kenneth Hand" mac-address=00:0C:42:*:*:*
add comment="Matlapeng Housing" mac-address=00:0C:42:*:*:*
add comment="Smily 54" mac-address=00:0C:42:*:*:*
add comment="Mossie Valentin" mac-address=00:0C:42:*:*:*
add comment="Gerda Theron" mac-address=00:0C:42:*:*:*
add comment="Henk Jakobs Huis" mac-address=00:0C:42:*:*:*
add comment="Elaine Besselaar" mac-address=00:0C:42:*:*:*
add comment="Leon Nortje" interface=wlan3 mac-address=00:0C:42:*:*:*
add comment="Kobus de Beer" mac-address=00:0C:42:*:*:*
add comment="Pierre de Villiers" mac-address=00:0C:42:*:*:*
add comment="Kobus Crous" mac-address=00:0C:42:*:*:*
add comment="Jaco van Staden" mac-address=00:0C:42:*:*:*
add comment="Diaan Kruger ( Velosity 2 )" mac-address=00:0C:42:*:*:*
add comment="Diaan Kruger ( Velosity 1 )" mac-address=00:0C:42:*:*:*
add comment="Lihan du Plessies 2" mac-address=00:0C:42:*:*:*
add comment="Jandre Viljoen" mac-address=00:0C:42:*:*:*
add comment="Juliana Griesel" interface=wlan3 mac-address=00:0C:42:*:*:*
add comment="Gideon Pietersen" interface=wlan2 mac-address=00:0C:42:*:*:*
add comment="Figo Mauricio" interface=wlan2 mac-address=00:0C:42:*:*:*
add comment="Andre Olivier" interface=wlan2 mac-address=00:0C:42:*:*:*
add comment="David Jasper" interface=wlan2 mac-address=D4:CA:6D:*:*:*
add comment="Laurika De Klerk" interface=wlan2 mac-address=D4:CA:6D:*:*:*
add comment="Andries Matiwane" interface=wlan3 mac-address=00:0C:42:*:*:*
add comment="Wesley Erlank" interface=wlan2 mac-address=D4:CA:6D:*:*:*
add comment="Madelein Markram" interface=wlan2 mac-address=00:0C:42:*:*:*
add comment="Jacob Collen" interface=wlan2 mac-address=D4:CA:6D:*:*:*
add comment="Nico Peenze" interface=wlan2 mac-address=D4:CA:6D:*:*:*
add comment="Johan Koch" interface=wlan3 mac-address=00:0C:42:*:*:*
add comment="Cindy Heinrich" interface=wlan2 mac-address=00:0C:42:*:*:*
add comment="Rooisand 30ste" interface=wlan2 mac-address=D4:CA:6D:*:*:*
add comment=Bestwood interface=wlan2 mac-address=D4:CA:6D:*:*:*
add comment="Codrey Mostert" interface=wlan2 mac-address=D4:CA:6D:*:*:*
The Client
# jan/02/1970 00:06:03 by RouterOS 6.7
# software id = XVHJ-152K
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n country="south africa" \
disabled=no frequency=5580 l2mtu=2290 ssid=""
The AP it does associate to.
# jan/10/2014 14:23:08 by RouterOS 5.21
# software id = 7PA5-9M0D
/interface wireless
set 0 band=5ghz-a/n comment="Kathu 50 meter toring Link na Redsands " \
country="south africa" disabled=no frequency=5660 ht-rxchains=0,1 \
ht-txchains=0,1 l2mtu=2290 mode=ap-bridge nv2-cell-radius=50 ssid=\
KA_Link_RS wireless-protocol=nv2
set 1 band=5ghz-a/n comment="380 Deg AP by 50 meter Toring" country=\
"south africa" disabled=no frequency=5240 ht-rxchains=0,1 ht-txchains=0,1 \
l2mtu=2290 mode=ap-bridge nv2-cell-radius=60 ssid=50meter_380 \
set wlan1 comment="Kathu 50 meter toring Link na Redsands "
set wlan2 comment="380 Deg AP by 50 meter Toring"
set wlan1 comment="Kathu 50 meter toring Link na Redsands " enable-nstreme=\
yes
set 0 vlan-mode=fallback
set 3 vlan-mode=fallback
add comment="Link na redsands" mac-address=D4:CA:6D:*:*:*
add comment="Tau by Suid myn Kumba" mac-address=00:0C:42:*:*:*
add comment="Rupert Robenson" mac-address=D4:CA:6D:*:*:*
Ok. Went to the neighboring town, about 90km away. Carbon copy of main site, a bit newer hardware but again RB433 with two PCI radio cards. OS 5.23. Took SXT Light and standard SXT. Both connected perfect. This is really confusing. Have eight AP on our main site and latest stock SXT Light does not want to associate to any of them. Older stock SXT Light has no problem to associate. Attached the export of above mentioned AP and SXT Light client that did connect, perhaps somebody picks up something.
AP export
# jan/10/2014 21:30:39 by RouterOS 5.23
# software id = XDI9-BGD5
/interface wireless
set 0 band=5ghz-a/n comment="AP_T3a op Posmas water Toring" country=\
"south africa" disabled=no frequency=5580 ht-rxchains=0,1 ht-txchains=0,1 \
l2mtu=2290 mode=ap-bridge name=wlan1 ssid=AP_T3a wireless-protocol=nv2
set 1 band=5ghz-a/n comment="Posmas sement Water toring na Poskantoor Link" \
country="south africa" disabled=no frequency=5500 ht-rxchains=0,1 \
ht-txchains=0,1 l2mtu=2290 name=wlan2 ssid=Toring_Link wireless-protocol=\
nv2
set 2 adaptive-noise-immunity=client-mode band=5ghz-a/n comment=\
"Was Lofti, nou spaar." country="south africa" frequency=5560 \
ht-rxchains=0,1 ht-txchains=0,1 name=wlan3 nv2-cell-radius=60 ssid=\
Posmas_Lofti_Link wireless-protocol=nv2
set wlan1 comment="AP_T3a op Posmas water Toring"
set wlan2 comment="Posmas sement Water toring na Poskantoor Link"
set wlan3 comment="Was Lofti, nou spaar."
set wlan1 comment="AP_T3a op Posmas water Toring" enable-nstreme=yes \
enable-polling=no
set wlan2 comment="Posmas sement Water toring na Poskantoor Link" \
enable-nstreme=yes
set [ find default=yes ] group-ciphers="" supplicant-identity=MikroTik \
unicast-ciphers=""
add comment="Link van Poskantoor af." interface=wlan2 mac-address=\
00:0C:42:67:05:C0
add comment="Riaan Koen" interface=wlan1 mac-address=00:0C:42:*:*:*
add comment="Richard Smit" interface=wlan1 mac-address=00:0C:42:*:*:*
add comment="Gerhard Brant" interface=wlan1 mac-address=00:0C:42:*:*:*
add comment="BC Access Point" interface=wlan3 mac-address=00:0C:42:*:*:*
add comment="Blue Chip link" interface=wlan3 mac-address=00:0C:42:*:*:*
add comment="Dan Gouws" interface=wlan1 mac-address=00:0C:42:*:*:*
add comment="Lofti se Toring" interface=wlan3 mac-address=D4:CA:6D:*:*:*
add comment="Herman Wepener" interface=wlan1 mac-address=00:0C:42:*:*:*
add comment="Link van Oom Lofti se berg." interface=wlan3 mac-address=\
D4:CA:6D:*:*:*
add comment="Electric City" interface=wlan1 mac-address=00:0C:42:*:*:*
add comment="Gereformeerde Kerk" interface=wlan1 mac-address=\
00:0C:42:*:*:*
add comment="Hannalie Pro-active" interface=wlan1 mac-address=\
D4:CA:6D:*:*:*
add comment=Photeque interface=wlan1 mac-address=00:0C:42:*:*:*
And the SXT light export file
jan/02/1970 06:23:06 by RouterOS 5.25
# software id = NR5L-S2CG
add l2mtu=1598 name=bridge1
/interface wireless
set 0 band=5ghz-a/n country="south africa" disabled=no frequency=5580 \
ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 ssid=AP_T3a wireless-protocol=\
nv2-nstreme
/interface eoip
add mac-address=02:8F:FBjan/02/1970 06:23:06 by RouterOS 5.25
/interface wireless
nv2-nstreme
/interface eoip
/interface wireless
nv2-nstreme
/interface eoip
add mac-address=02:8F:FB:FF:A4:92 name=Kamera remote-address=192.169.81.200 \
tunnel-id=100
add bridge=bridge1 interface=Kamera
/interface wireless
nv2-nstreme
/interface eoip
tunnel-id=100
/interface wireless
nv2-nstreme
/interface eoip
tunnel-id=100
/interface wireless
nv2-nstreme
/interface eoip
tunnel-id=100
/interface wireless
nv2-nstreme
/interface eoip
tunnel-id=100
/interface wireless
nv2-nstreme
/interface eoip
tunnel-id=100
/interface wireless
nv2-nstreme
/interface eoip
tunnel-id=100
/interface wireless
nv2-nstreme
/interface eoip
tunnel-id=100
/interface wireless
nv2-nstreme
/interface eoip
/interface wireless
nv2-nstreme
/interface eoip
add mac-address=02:8F:FB:*:*:* name=Kamera remote-address=192.169.81.200 \
tunnel-id=100
tunnel-id=100
tunnel-id=100
tunnel-id=100
No ideas? Got 40 of these units, did not want to send them back to the supplier if it is something i could fix.
If possible try to reset the wireless interface configuration on the AP and on the non-working station and then configure the settings you only need.
Also please upgrade the AP and the Clients to RouterrOS v5.25 or v6.7
Also try to use only AES encryption instead of TKIP.
Enable the wireless,debug logging on the AP and on the client and check the logs.
Disable the access-list entries and check if they are not causing the problem.
Hi Uldis
Thanks for the response.
Wont be able to reset AP, production AP, but it does function with other clients, including
Have already upgrade both client and AP to 6.7
Using NV2, don’t think encryption should be a problem?
Will try this, but i believe there will be a enormous amount of info coming in, but will give it a try.
Looks like this might be it, perhaps a bug? Default authentication is on, but after disabling the access-list entries, none of the clients could associate with the AP. After enabling them, the associated again.
Took the AP that the SXT Lite does associate with and disabled access-list. Could still associate. This AP had OS 5.23. Upgraded to OS 5.23 to OS 6.7. SXT did not want to associate until i enabled access list entry. Same error in log as other AP’s, not allowed. Keep in mind default authentication is enabled. The PTP link, which is also a RB433, did not have a problem and could associate with access list disable even after upgrading to OS 6.7
Just to test this, i added the clients mac to the access list. It immediate associated with AP. This AP has default associate on, this should not happen, but is clear now.
We upgraded these AP software to to 5.25 in December. Only reason why all the clients could still associate to Ap was that by chance we, as a default, add all clients to the access list. At around the same time we received the SXT lights, but because off holidays and new year no installations was done. Never put 1 and 1 together until now. OS 6.7, same problem. In order to test this i did downgrade the PTP RB433 to OS 5.14. Client could associate again to it.Only conclusion i can make is that there is nothing wrong with SXT Light but that Default authentication is broken in new OS versions.
I have the same problem as you. The difference is that i have about 2000 of SXT 5nD r2 working in my network .
This problem appears on every os ver. 6.X and 5.2X
i tried:
upgrding fw to 6.7 also on ap - not working
the only solution for now is calling our customer and asking Them for sxt reboot, but this not always helps.
the solution described above doesn’t work for me
any ideas what else can I do?
What i found was in the wireless security profile, the radius - mac authentication option was enabled. When i disabled this option, every thing was functioning as expected.
A question if a may Emboro. What is the max users you ave connected to a AP?
