I have a link using RB912 board & stations using RB SXT Lite5.
Let’s say, the RB912 has an IP 10.10.10.2 and the stations have IPs in this range.
When I connect one of those stations by Ethernet to my laptop and open WinBox 3.4, I can only see this station and the neighbors don’t appear noting that it is connected to the RB912 and I can see the neighbors from inside the Router OS in IP > Neighbors, but the laptop can’t ping any of those addresses nor connect to them even if I set manual IP for the laptop on same network.
Any Advise?
Another question regarding the settings of the station, in Wireless, I choose station WDS but the thing is, it keeps reverting to station bridge. Is that normal?
For an network to be transparent (layer 2) AP must be set in ap bridge and station bridge for clients. Routing must be disabled. I’m pretty sure yours aren’t set in this way.
Why routing have to be disabled? What you mean by saying that?
Maybe that’s because you have separate broadcast area (L2) on wifi and lan. Use bridge and add eth1 and wlan1 to it, and you will see all mt’s
Any Advise?
Read about network layers
yes
