SXT Lite5 P to P low speed
Hello!
Could someone provide me to the right configuration of SXT Lite5?
We need to establish point to point link. Distance is 633 meters. No routing.
We configured 2 x OEM SXT like this:
1.) We wrote local IP adress
2.) Bridge Lan-Wlan
2.) NV2 wireless protocol + security key
3.) Switched on both chains
4.) Scanned a clear frequency
The problem is that we can not get higher speed than 35-42 Mbps in each direction. Only 633 meters.. Is it normal? Or there are some other options that we need to know? How much is possible to get trough at all for this model?
Thank you very much for your help!
Can you give some details ? Signal strenght, CCQ, SNR…
ROS Version?
Wireless-Mode
Old or New Wireless Packages?
Mistry7
