Hi to all,I,m beginer and need help!
I have SXT Lite5 and need help to update with new sw.
Where to find it, what is last version and how to update !
Need all your help, please have an understanding for questions like this !!!
Here you will find what is the most recent version: http://www.mikrotik.com/download (for the moment of writing it is 5.24)
Login to the router via Winbox or Webfig. Then on the Quickset page click on the ‘Check For Updates’ button.
Thank You for answer, need little more explanation, step by step !
type in the address bar http://192.168.88.1/ you should see the login panel to the router.
Hi, it is done !
Now, where I can find how to configurate sxt ?
