SXT Lite5nD r2 - bricked
I have been trying to debrick my SXT Lite5nD r2 but Netinstall is not working well.
Everytime when I click install button i get stuck on “Partitioning and formating harddrive” and then it reboots.
Please help.
Generate a supout.rif and send it to support, linking to this post.
Where can I get that file. I can’t access RB.
Ouch… you’re right.
Are you directly connected to it? have you tried another laptop? Have you used that same laptop to netinstall other devices? have you tried a different PSU and POE injector with the SXT?
This is to rule out the possibility of the issue being network interface/cabling/POE related.
Looks like the NAND of that SXT is damaged, so I’m afraid writing to support is your only chance if those methods don’t work.
