Playing around with my newly received SXT LTE. I live 200 meters from a 3G antenna. When using sim-card in my mobile phone, I get very good 3G readings and so-so LTE readings. I prefer 3G as, in my case, the latency is lower.
Using the sim-card with the SXT LTE, I can connect to LTE with so-so readings when the APN is correctly configured. Aiming the SXT LTE at the 3G antenna, I still get LTE connection (and it’s not that good). After forcing the SXT LTE to use 3G only, I do not get any connection at all, but still it seems to have some kind of communication, with CSQ: 30,99, which I have read somewhere is a good value.
I have attached some logs here, hidden some numbers that might be sensitive.
Do you have any suggestions how to continue?
Thanks!
01:05:08 system,info device changed by admin
01:05:08 lte,async lte1: rcvd OK
01:05:08 lte,async lte1: sent AT+CFUN=4
01:05:10 lte,async,event +CGEV: EPS DED DEACT 1,5
01:05:10 lte,async,event +CREG: 1
01:05:10 lte,async,event +CEREG: 0
01:05:10 lte,async,event +CGEV: ME DETACH
01:05:10 lte,async,event +CREG: 0
01:05:10 lte,async lte1: rcvd OK
01:05:10 lte,async lte1: sent AT+CMEE=2
01:05:10 lte,async lte1: sent AT+CREG=2
01:05:10 lte,async lte1: sent AT+CGREG=2
01:05:10 lte,async lte1: sent AT+CEREG=2
01:05:10 lte,async lte1: sent AT+CGEREP=2,0
01:05:10 lte,async lte1: sent AT+CMGF=0
01:05:10 lte,async lte1: sent AT+CNMI=1,1,0,1,0
01:05:10 lte,async lte1: sent AT+EEMOPT=1
01:05:10 lte,async lte1: sent AT*MRD_SN?
01:05:10 lte,async lte1: rcvd *MRD_SN:******************
01:05:10 lte,debug lte serial: *MRD_SN:******************
01:05:10 lte,async lte1: sent AT+CFUN=4
01:05:10 lte,async lte1: sent AT*CGDFLT=0,"IP","services.telenor.se",,,,,,,,,,1,0,,,,,,,1
01:05:10 lte,async lte1: sent AT*CGDFAUTH=0,0
01:05:10 lte,async lte1: sent AT+CPIN?
01:05:10 lte,async lte1: rcvd +CPIN: READY
01:05:14 lte,async lte1: sent AT+CPMS="SM","SM","SM"
01:05:14 lte,async lte1: rcvd +CPMS: 2,30,2,30,0,0
01:05:14 lte,async lte1: sent AT+CFUN?
01:05:14 lte,async lte1: rcvd +CFUN: 4
01:05:14 lte,async lte1: sent AT+CNUM
01:05:14 lte,async lte1: rcvd +CME ERROR: 100
01:05:14 lte,async lte1: sent AT+CIMI
01:05:16 lte,async lte1: rcvd ******************
01:05:16 lte,async lte1: sent AT+ICCID?
01:05:16 lte,async lte1: rcvd +ICCID: ******************
01:05:16 lte,async lte1: sent AT+CPIN?
01:05:16 lte,async lte1: rcvd +CPIN: READY
01:05:16 lte,async lte1: sent AT*BAND=1,78,147,160,524487,0,2,0
01:05:16 lte,async lte1: rcvd OK
01:05:17 lte,async lte1: sent AT+CFUN=1
01:05:17 lte,async,event +CREG: 2
01:05:17 lte,async,event +CGREG: 2
01:05:17 lte,async lte1: rcvd OK
01:05:17 lte,async lte1: sent AT+COPS=3,0
01:05:17 lte,debug lte1: config ok
01:05:17 lte,async,raw lte1: sent AT+EEMGINFO?
01:05:17 lte,async,raw lte1: rcvd OK
01:05:17 lte,async,raw lte1: sent AT+CSQ
01:05:17 lte,async,raw lte1: rcvd +CSQ: 99,99
01:05:19 lte,async,event +CREG: 11, 186, 13c9a9, 2
01:05:19 lte,async,event +CGREG: 11,"0186","0013c9a9",2,90
01:05:20 lte,async,raw lte1: sent AT+EEMGINFO?
01:05:20 lte,async,raw lte1: rcvd OK
01:05:20 lte,async,raw lte1: sent AT+CSQ
01:05:20 lte,async,raw lte1: rcvd +CSQ: 30,99
01:05:23 lte,async,raw lte1: sent AT+EEMGINFO?
01:05:23 lte,async,raw lte1: rcvd OK
01:05:23 lte,async,raw lte1: sent AT+CSQ
01:05:23 lte,async,raw lte1: rcvd +CSQ: 30,99
01:05:26 lte,async,raw lte1: sent AT+EEMGINFO?
01:05:26 lte,async,raw lte1: rcvd OK
01:05:26 lte,async,raw lte1: sent AT+CSQ
01:05:26 lte,async,raw lte1: rcvd +CSQ: 30,99
01:05:29 lte,async,raw lte1: sent AT+EEMGINFO?
01:05:29 lte,async,raw lte1: rcvd OK
01:05:29 lte,async,raw lte1: sent AT+CSQ
01:05:29 lte,async,raw lte1: rcvd +CSQ: 30,99
01:05:32 lte,async,raw lte1: sent AT+EEMGINFO?
01:05:32 lte,async,raw lte1: rcvd OK
01:05:32 lte,async,raw lte1: sent AT+CSQ
01:05:32 lte,async,raw lte1: rcvd +CSQ: 30,99
01:05:35 lte,async,raw lte1: sent AT+EEMGINFO?
01:05:35 lte,async,raw lte1: rcvd OK
01:05:35 lte,async,raw lte1: sent AT+CSQ
01:05:35 lte,async,raw lte1: rcvd +CSQ: 30,99
01:05:38 lte,async,raw lte1: sent AT+EEMGINFO?
01:05:38 lte,async,raw lte1: rcvd OK
..... and it continues like this forever
