Sxt lte and router
Hi, I bought a sxt lte kit that I would like to connect to a router on wan slot. On router side I have a firmware similar to Asus router. I configured sxt with an lte account with chap login and it connect correctly to lte. I attached the eth1 to wan port. I can se it connected to router and I can open web interface with sxt default ip so seems to be correctly connected. The problem is that I can not access to lte on router side and browser internet. Seems as lte is working separately to eth1.
What kind of setting I have to do? I am a novice of mikrotik maybe is an easy task. Thanks in advance
Hi, I reset router and updated to last firmware. Now it’s working correctly on wan router port but seems slow.
I have a hawei 5186 with 100snr while sxt has 95 but on speed test connected to same 3 band with the first I arrived also 25 mbps while with sxt only 9mbs in download and 10 versus 5 in upload, ping is around 98 with first and 112 with sxt. . There are setting that can slow down speed?
