I just bought an international sxt-lte kit.
it does not recognize the lte r11e-lte modem
I have already updated Routers to 6.45.3
I already added the command - / system routerboard usb type = mini-pcie nothing
friends could help me
- Might want to try boot delay to 5s in System > Routerboard > Settings if that’s not already set.
- Check that System > Resources > USB sees the modem module on the USB bus
- Try the “long-term” OS version, (in Winbox, System > Packages > Check For Updates, select “long-term” then “Download and Intstall”).
- You might want to have a SIM card inserted, even if the carrier is not active on it (should work without but…)
RMA.
Regards.
