I’m really liking the look of the SXT LTE, it may be the answer to a number of problems I have.
Can anyone hazard a guess that the potential throughput capability of the device if I’m running an IPsec tunnel that terminates on the device? I’m in control of both ends so can choose encryption and digest standards (but it does need to be encrypted, so aes-128 probably)
I notice no hardware acceleration and a relatively slow CPU, 40Mbps and up would make it viable?
(It’s possible I could terminate the tunnel on a more powerful device, but it would make it more complex, so I’d like to keep it at a single device if possible)
However a rb3011 could be a better suit depending on your scenario, this unit should do 40+ Mbps without doubt, and it has hardware accelerator support on the works.
