SXT LTE IPv6 possible without DHCPv6?
I have a RBSXTR&R11e-LTE-US (RouterOS 6.48.5, R11e-LTE-US MPSS: R11eL_v16.02.183961 APSS: R11eL_v05.03.183961 CUSTAPP:) where the cell provider offers IPv6, but only the SXT exhibits IPv6 connectivity. IPv6 traffic on the LAN side of the firewall is sent out to the WAN, but when the cell provider generates a Neighbor Solicitation in order to deliver response, this is ignored by RouterOS.
My previous experience seems to suggest that RouterOS will work correctly (providing IPv6 connectivity for a /64 subnet) with a IPv6 provider when the “M bit” (Managed address configuration) is set in the Router Advertisement and RouterOS is configured with a DHCPv6 client for said provider.
As you can see below, this IPv6 provider does not have the M bit, and so does not provide a DHCPv6 server:
Internet Control Message Protocol v6
    Type: Router Advertisement (134)
    Code: 0
    Cur hop limit: 64
    Flags: 0x00, Prf (Default Router Preference): Medium
        0... .... = Managed address configuration: Not set
        .0.. .... = Other configuration: Not set
        ..0. .... = Home Agent: Not set
        ...0 0... = Prf (Default Router Preference): Medium (0)
        .... .0.. = Proxy: Not set
        .... ..0. = Reserved: 0
    Router lifetime (s): 45
    Reachable time (ms): 0
    Retrans timer (ms): 0
    ICMPv6 Option (Prefix information : 2607:XXXX:XXXX:XXXX::/64)
    ICMPv6 Option (Route Information : High ::/0)
    ICMPv6 Option (Recursive DNS Server 2001:4860:4860::8888 2001:4860:4860::8844)
    ICMPv6 Option (Source link-layer address : 1a:82:1b:XX:XX:XX)
The /ipv6 nd capability clearly works, as RouterOS is aware of the assigned prefix:
[admin@MikroTik] > /ipv6 address print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
 #    ADDRESS                                     FROM-... INTERFACE        ADV
 0 DL fe80::XXXX:XXXX:XXXX:XXXX/64                         bridge           no
 1 DL fe80::XXXX:XXXX:XXXX:XXXX/64                         lte1             no
 2 DG fec0:0:0:ffff::1/64                                  bridge           no
 3 DG 2607:XXXX:XXXX:XXXX::/64                             bridge           yes
 4 DG 2607:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:f562/128          lte1             no
From a PC on the LAN side of the Mikotik, I do a ping6 2607:f8b0:4000:809::2004
The LAN-originated ping goes out the lte1 interface without issue:
Internet Protocol Version 6, Src: 2607:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:3e29, Dst: 2607:f8b0:4000:809::2004
    0110 .... = Version: 6
    .... 0000 0000 .... .... .... .... .... = Traffic Class: 0x00 (DSCP: CS0, ECN: Not-ECT)
    .... .... .... 0111 0100 0000 1010 1100 = Flow Label: 0x740ac
    Payload Length: 64
    Next Header: ICMPv6 (58)
    Hop Limit: 255
    Source:  2607:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:3e29
    Destination: 2607:f8b0:4000:809::2004
    Type: Echo (ping) request (128)
    Code: 0
    Identifier: 0x235b
    Sequence: 11
    [No response seen]
For every LAN-originated outgoing ping message, on the lte1 interface there is the following response that RouterOS seems to ignore:
Internet Protocol Version 6, Src: fe80::XXXX:XXXX:XXXX:XXXX, Dst: ff02::1:ffXX:3e29
    .... .... .... 0000 0000 0000 0000 0000 = Flow Label: 0x00000
    Payload Length: 32
    Hop Limit: 255
    Source: fe80::XXXX:XXXX:XXXX: XXXX
    Destination: ff02::1:ffXX:3e29
    Type: Neighbor Solicitation (135)
    Code: 0
    Reserved: 00000000
    Target Address: 2607:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX:3e29
Here is the configuration, the bulk of which is just the standard Mikrotik configuration. About the only customization is in the APN where the provider specifics are used and ipv6-interface is used to generate the Router Announcements on the LAN:
/interface lte
set [ find ] name=lte1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=fast.t-mobile.com ip-type=ipv4-ipv6 \
    ipv6-interface=bridge
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add comment=defconf interface=lte1 list=WAN
    192.168.88.0
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
