sxt lte KIT choose cell tyower
hi.
I’m begginer in LTE router, and what to select cell tower manualy.
I need to do this, because, its usualy the cell tower where my SXT is connected with a good signal, the internet is not comming.
Any idea please.
The best is call to your ISP and inform that in these “zone”, the Internet is not working or is terribly slow to what a technician check the tower. I did it one time and in one day the problem was solved.
Regards.
thanks for your reply
I use this SXT for event, and I can not wait the answer from the operator.
i’ve used GSM Gateway in the past, and I’ve this possibility to connect some line on specific cell tower. the advantage is to choose an avaible or unsed tower and have a good quality of call
Hi
Send me a print out of your config.
I have had issues where SXT LTE get’s good signal but no internet, and always it turned out to be a config issue.
Run the following command.
/export file="mysettings.txt"
Before posting it here, please go through it and remove any username/password that appears in it. For security reasons.
