Hello.
I have bought a SXT LTE Kit and I am unable to insert a Micro SIM card into the SIM A Slot. Insert it on SIM B slot seems, yet, more difficult.
The Micro SIM that I have is standard size. It works correctly on some phones. But I tries to insert it on the card slot on the SXT LTE Kit and don’t enter. The card slot seems to be less high than the MIcroSIM card.
I only open the small lid of the case. I don’t know if it is necessary to open all the case but I don’t see a way to do it.
I have not found any instructions or ilustration how to do it.
I am wondering if it is necessary to use a special tool to insert the Microsim card into the slot.
THank you very much for any help.
