maybe this is for general topic…don’t know. When using some Huawei LTE modem 4G as gateway to network with 100 users it just hangs every hour or so. Is it because large amount of packets that router cannot handle or/and because of limit of SIM card (3G 4G technology). If I use SXT LTE with 4G card would it be able to handle over 100 users on network as gateway? Does anybody has experince with this kind of stuff?
The bottleneck is the soho router. Using mikrotik should be better but I would use another router for client management because sxt lte has low end hardware. Use RB750r3 or 3011.
Well I guess same thing happens with this Huawei modem. I assume it is packet handling issue. It simply blocks and needs reboot. But then again simple ADSL router manages to hang on in same conditions without problem. I think I will get one SXT LTE just to see how it will manage.
