Just few days ago I have installed SXT LTE. At first, I have update RouterOS Stable Ver.(6.48.1) and also LTE firmware(MikroTik_CP_2.160.000_v018). I have notice that everyday Internet stop working. Ping result 100% Packet Loss. Under LTE interface, Cellular & Status Tab show correct information. Finally, I have check the logs and found that lte1 link down->registered home->lte1 link up. So, every time need reboot the device.
Is it the right way to fix this problem?
My previous LTE router(Huawei B315-936) was good better than Microtik.
This is not normal behavior, device should un-brick, change tower, re-connect, go to 3g etc.
This case should be diagnose, check my KB link at signature and do enable logs and show us problem with logs.
