I’ve just taken over a system in the French Alps, with two SXT LTE’s. They’ve both got ‘Free.fr’ SIM’s in, and im struggling to get them to connect to an lte signal…
Ive reset the systems, and used the quick set to get started, but neither are generating an IP, and when I go into the interface section of webconfig, but are saying invalid sim. Any ideas?
Free.fr uses B3, B7 and B28. SXT LTE (first version) is compatible with B7, and the newest SXT LTE kit, is compatible with B3 and B7. You need to check that the nearest tower is not B28.
