SXT LTE - wireless module replacement to cat 4?
Is it possible to replace the wireless module in SXT LTE with for example a cat-4 module from Sierra (or from whatever supplier) that works with RB?
Btw, just a thought. Why not sell SXT LTE and the LTE modules separately? In that way you could supply LTE solutions that covers all future categories and channels around the globe...
Thanks in advance!
Ok, is it possible to replace the wireless module?
I don’t have one so I can have a look in the inside. I’m looking for Cat-4 solution to be used as fail-over, that’s why I’m asking. Won’t any of these mini-pci LTE cards work “out of the box”: http://wiki.mikrotik.com/wiki/Supported_Hardware#4G_LTE_cards_and_modems
We will have LTE products soon that will have LTE modules removable or available separately, but the SXT LTE that you have, can’t be upgraded that way.
Thanks for the feedback, looking forward to the new version!
