SXT LTE6 kit + DualSIM + Dual Port
Hey there,
do someone know that’s possible what I’d like to do with a “SXT LTE6 kit”
  • Can I use both SIM slots parallel, so I can two connections separately (SIM A to ISP A + SIM B to ISP B)?
  • Can I have one ethernet port 1 (PoE in) to put ISP A network on it and ethernet port 2 (PoE out) to put ISP B network on it?
Thank you very much for any helping information!
Hi, SXT as only one LTE miniPCIe card, so you can only use one ISP. The dual SIM slot is probably to switch between both SIM cards but you can’t use both at same time by hardware limitation.
With RBM33G you can do it, because have 3 Ethernet ports and 2 miniPCIe slots.
Regards.
Thank you! Helped me a lot :slight_smile:
