SXT LTE6 kit or LHG LTE6 kit
Hi All,
I currently have a LtAP LTE device, which I am impressed with but does seem to struggle at times as its currently in the loft. As my cell tower is around 3.5KM but unfortunately it’s not a clean line of sight as it has a number of houses in the way I have been looking at the SXT LTE6 kit or LHG LTE6 kit models as a more permanent setup. Ideally, I’d like to put the devices outside but access to get it high enough is very limited, so I am using the loft at the mo.
The current signal levels are around RSSI -45dB / RSRP -78db, so it gets a good level.
Thanks.
I would pick one depending on what band frequency you need. Ive used both. The sxt connected to one band better than then lhg, and vice versa. I would choose according to what band you need/want.
Sent from my Z6530V using Tapatalk
